How do I take the hold off the setting on thermostat ?
    Problem Solver:
  • 11 Answers
Usually by holding the hold button down or changing the temperature.
Posted on Nov 17, 2014
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
What does temporarry and hold mean on thermostat
Sounds like you have a programable thermostat. the temporary setting is when you change the temp setting to a different temp and it will stay at that setting until the next programed change. The hold setting is to hold the temp setting you have chosen for an indefinate time. It overrides your programed settings.
Jul 06, 2012 | Honeywell Programmable Thermostat Heater
My grandchildren played with my thermostat yesterday and unfortunately I can’t get it to where I’ve had it for the last 6 yrs. I have it set at 70 degrees and it elevates after 1 hr or 2 to 78 on the...
Your thermostat should have a hold feature indicated by "hold" on or near the hold button. Once this button is pressed "hold" should be indicated somewhere on the screen. When the hold feature is activated your thermostat should stay at the given set-point indefinitely.
If you would like to use the program feature of your thermostat I need to know the make and model before I can help you.
Aug 26, 2010 | Heating & Cooling
I'm having a problem with my thermostat. It's a
Set Current Time and Day
1. Press TIME button once. The display will show the hour only.
EXAMPLE: PM
2. Press and hold either or until you reach the correct
hour and AM/PM designation (AM begins at midnight; PM
begins at noon).
3. Press TIME once. The display window will show the minutes
only. 1F80-361 pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 14, 2010 | Heating & Cooling
I keep setting my thermostat but it automatically goes back to same temperature no matter what i set it at
If it is a programmable thermostat, it will only stay at a certain temp until it reaches it or on a set time, then it goes back to the scheduled program temperatures. Most programmable thermostats do have a hold feature that allows you to hold the temp to a certain setting, but if you don't set it to permanent hold, then it does what you described. Hopefully this helps some or guides you in the right direction. Good luck!
Mar 12, 2010 | Heating & Cooling
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have 3 Duracraft thermostats. We have recently had problems with all 3 switching from Centigrade to Farenheight and back. Batteries changed with no resolution. When they switch to Centigrade they don't...
On some programmable thermostats you need to hold either the up and down buttons together to get
the thermostat to stay on farenheight.
It could also be that you will have to go in the program and make sure you set it to farenhieght.
On the back of some T-stat covers it will explain how to do this
Jan 03, 2010 | Honeywell Electronic Programmable...
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 16, 2009 | Honeywell Programmable Thermostat Heater
Holding Program
Try pressing the hold button till it says permanent hold. Then adjust the temperature to the desired setting. Depending on the model of it, you might have the option of a vacation hold, then you can set the temperature to the desired setting for a specific number of days.
May 01, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
