Question about HP Office Equipment & Supplies
A previous employee set our office printer to "self-clean" and now it is doing so after every print job. how do i turn this off? operating system windows 7 printer HP laser jet 600 series m603
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 884 Answers
Hi
You should be able to change the settings as follows:
At the product control panel, press the Home button, select the Device Maintenance menu, and then select the Calibrate/Cleaning menu. Here you can turn auto-clean on and off, specify how pages to print before an auto-clean, and the cleaning size (Letter or A4)
For future reference this is on page 32 of the User Guide (Page 48 of the pdf file which can be obtained here:
http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c02677203-7.pdf
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 17, 2014
Testimonial: "thank you thank you thank you"
SOURCE: laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Posted on Nov 12, 2008
SOURCE: Can't print to a shared HP Laser Jet 2015 printer (Mac)
On the two non working computers...uninstall the printer drivers and uninstall any info about the printer reboot.reset up each indivual (the two non working ones)computer with new drivers from web.reboot and they should work.RICHARDM69
Posted on Dec 05, 2008
  • 1684 Answers
SOURCE: HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: I have installed Windows 7 now How to connect HP
When you installed Win7, did you upgrade or did you do a Clean install? If you performed an upgrade, you may have the problem with older conflicting drivers and services. Read this to see what I mean. http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm
Posted on Jul 20, 2009
SOURCE: Printer is printing black lines across all print jobs
i would check the fixing section of the machine which is the hottest part of the machine. weather it is a film or roller you probley have a mark that unit
Posted on Dec 04, 2009
Brother HL2130 press print and i want to stop the printing how to i pause or cancel printing do i just open the lid or can't be cancelled i tried to search via settings but unable to locate thankyou
most likely it has gone into the printer's memory.
Turn off printer at power point.
CHECK COMPUTER FOR PRINTER QUEUE
Also check computer for printers icon on right bottom of screen and click on it to open the printer queue.
Then cancel print job if in Windows operating system's printer pool.
Turn printer back on at power point
If you can't find the printer queue go to printer settings in the control panel of the p.c and find the printer queue.
If this is not possible for you to find.
Go to services (in control panel) if windows operating system and find the print spooler service and restart the service .
May 25, 2017 | Brother Office Equipment & Supplies
Printer continues to print even though copies reads 1. possible holdover from previous job
go to control panel--- devices and printers --click on printers and see what is printing--delete all things that are not printed
Jan 26, 2017 | PRINTER Office Equipment & Supplies
My printer wasn"t working when I had tried to
Hi pjmgranny !
Yes , you can cancel the previous printing jobs .
under Win XP :
go to start \ settings \ printers and faxes , select the jobs , clic on documents and cancel .
under Win 7 :
go to start \ devices and printers . Right clic on the printer , select open \ documents in queue \ select documents and cancel
Best regards ,
fanaudi .
Feb 21, 2011 | HP DeskJet D2560 InkJet Printer
Even since we install the edimax server, the printer will just halt and we have to reset the spooler again
Setting the location of the spool folder By default the spool folder is located at systemroot\System32\Spool\Printers. However, this drive also holds the Windows system files. Because these files are frequently accessed by the operating system, performance of both Windows and the printing functions might be slowed.
If your print server serves only one or two printers with low traffic volumes, the default location of the spool folder is sufficient. However, for high-volume printing requirements, to support large numbers of printers, or to support large print jobs, you should relocate the spool folder. For best results, move the spool folder to a drive that has its own controller, which reduces printing's impact on the rest of the operating system.
For information on relocating the print server spool folder, see Change the spool folder location.
To set up a printer to print to multiple devices
  1. Open Printers and Faxes.
  2. Right-click the printer you are using, and then click Properties.
  3. On the Ports tab, select the Enable printer pooling check box.
  4. Click each port where the printers you want to pool are connected.
Notes
  • To open Printers and Faxes, click Start, and then click Printers and Faxes.
  • With printer pooling, the printers must be the same type of printer using the same printer driver.
  • The previous procedure assumes the printers you want to pool are already in the Printers and Faxes folder.
  • Check for print jobs in que,this can cause the printer to spool if a print job is in que.
Dec 09, 2010 | Edimax PS-3103P (ps-3103p) Print Server
How do I turn on my RAM disk? (Dell 3100cn)
the print job may be too large for the available printer memory.
Your choices are one of the following:
Press to clear the message, cancel the current print job, and conduct the next print job, if any.
· Press Cancel to cancel the current print job.
· Press Menu to open the Stored Print and delete the current job.
To avoid this error in the future, do the following:
· Reduce the number of print pages such as splitting the print data.
· Increase free memory space by deleting unnecessary data in the RAM disk.
As for the RAM disk:
When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory.
Whenyou are ready to print the job, you must go to the printer and use theoperator panel menus to identify which job in the memory you want toprint. You can use this function to print a confidential job (SecurePrint), or verify one copy before printing additional copies (ProofPrint).
NOTE: The printer holds the job until you delete it byusing the operator panel or you turn off the printer. (This is the RAMdisk)
NOTE: Print and Hold functions require a minimum of 320 MBavailable printer memory. Also, you need to configure the RAM disksettings on either the OPERATOR PANEL OR THE PRINTER DRIVER.
NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs.
RAM disk is an option for that printer, but most users do not have thatoption, and if you accessed the menu for the 3100 on most of themachines in use you would receive that same error.
Although the printer itself shows " ready to print", this does not meanthat your computer is communicating with the printer. In Fact, thatmessage would show up even if you did not have it attached to anycomputer, as long as it was turned on and passed the self test.
More then likely the problem lies within the computer, NOT the printer.
To test the printers functionality, try printing a menu item, from the"reports" menu. Select either the printer settings, or the PCL Fontsreport. When selected, the printer should print which ever report youselected.
One thing you may want to check is to see if there are any print jobs "locked up " in the print spooler on your computer, and also make surethat the printer is not set to "work offline".
To do this, open the control panel, go to your "printers" folder, then double click on your printer.
This will open up the printer information for that printer. If there are any jobs in the print queue, they will show up here.
if there are any print jobs stacked up, usually it is the top job thathad a problem and is "stuck". This will prevent any job sent after thatto be held, pending release of that one.
single click the top job and either restart the job, or delete it.
Also, make sure that the printer is not set to work offline by clickingon "printer" from the menu and ensure that work offline is not checked.
Take this link and print it out. It will help you later when you get "other" error messages.
http://support.dell.com/support/edocs/sy...
Sep 18, 2009 | Dell Office Equipment & Supplies
Job automatically stops
It might be easiest to reset the printing system and then add your printer(s) again. It may be that you have something stuck in the printer queue that is causing the problem.
To reset the printing system in OS X 10.5.x, open the Print & Fax System Preference. Control-click (right-click) in the list of printers on the left side. Choose the option to reset the printing system. You will need to add your printer again after you reset the printing system.
Another possibility is that you may need to reset something from the printer's control panel. The printer may be rejecting your jobs until fault from the previous job is cleared.
Aug 07, 2009 | HP C3180 All-In-One InkJet Printer
Printer problem
Cancel all print jobs because most likley you have an error in a print job so cancel them shut off your printer turn it on nd try to print again
BestWishes                  -SunShine-
Jul 04, 2009 | HP LaserJet P2015dn Printer
How do i cancel a print in queue? thanx
Depends on your operating system. Start > settings >printers. Or Start printers and faxes. Find your printer and double click to open. Select printer job and right click to get to delete/clear or go to the printer menu and cancel all print jobs. Another way is to turn printer off for about 20 minutes to clear its memory.
Mar 10, 2008 | Computers & Internet
Ram disk
Stangowner, In this case, the print job is too large for the available printer memory. Your choices are one of the following: Press to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the current print job. · Press Menu to open the Stored Print and delete the current job. To avoid this error in the future, do the following: · Reduce the number of print pages such as splitting the print data. · Increase free memory space by deleting unnecessary data in the RAM disk. As for the RAM disk: When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory. When you are ready to print the job, you must go to the printer and use the operator panel menus to identify which job in the memory you want to print. You can use this function to print a confidential job (Secure Print), or verify one copy before printing additional copies (Proof Print). NOTE: The printer holds the job until you delete it by using the operator panel or you turn off the printer. (This is the RAM disk) NOTE: Print and Hold functions require a minimum of 320 MB available printer memory. Also, you need to configure the RAM disk settings on either the OPERATOR PANEL OR THE PRINTER DRIVER. NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs. Take this link and print it out. It will help you later when you get "other" error messages. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html And here's a link for more "operational" situations. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section16.html#1087088 ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Dell 3100cn Laser Printer
mukhtar21 shaikh
mukhtar21 shaikh
