Question about Electrical Supplies
I have a Rheem 18,000 watt propane generator at my cabin. It is powered by propane. It is not on the grid, but used to charge my solar system and heat hot water. I just installed a new battery and
Not on the grid-used with 8 battery solar system
    New Friend:
  • 58 Answers
What's the question ?
Posted on Nov 26, 2014
I am getting an older 8HP Coleman generator 4000 watts output. . My proposed solution is to install isolated outlets directly from the generator output to certain areas in the home.
You need to consult a local electrician, if you do this wrong you can cause allot of damage. We can only guess as to the correct way to do this without being there and looking at the wiring setup.
Oct 23, 2016 | Electrical Supplies
Is this true or scam Government pays you to go solar.
The US government WILL NOT PAY you to go solar. There have been incentives on the state level to get people to install solar panels. Most of these have dried up but it is possible to find programs that will reimburse you a portion of the total cost but don't expect much. We live in Florida and in 2009 we were promised nearly 1/2 back if we installed. We got less than 10% when all was said and done and it took 2 years to get that.
Aug 18, 2015 | Miscellaneous
I have solar panels that put out a little more voltage then they are rated at,and they keep faulting out my grid tie inverter.I need a resister to knock down the voltage about 8 volts, got any ideas?
I like to ask, is the voltage from the solar panel messure with some load connected or is open circuit, normally solar panels produce high voltage than the working system, the reasson for that is to have Amperes in of to charge the batery, these is related to the size and power generated by the panel.
No need a resistor or in any case use a voltage regulator to prevent over charge.
Apr 14, 2015 | Inverter Electronics - Others
I have a 3000 watt magnum energy sine wave inverter/ charger. It is hooked up to 5 -12 volt glass matt batteries. the charger used to charge in bulk mode @ aprox. 80 amps then absorb charge and then went...
I'm sorry that I can't help you, but if you're in a hurry, you can visit the Magnum website at: http://www.magnumenergy.com/Service/Servicefront.htm and try to find your model's online manual and search troubleshooting advice or you can email customer service at
support@magnumenergy.com and they should at least be able to lead you in the right direction.
A few questions: Does this problem remain even when there is at least a 10+ watt load on your system? is your Magnum in a hot environment? Does your inverter feel extraordinaryily hot? Have your batteries outlived their lives? Have you cleaned all the connections? Even if they 'look' like they don't need it?
All the best to you.
Sep 10, 2011 | Magnum Energy Inverter Fet Board Tfbrd3924...
I am building an off grid cabin but will need to meet code providing all electrical components as per the latest NEC. I will be using a 4100 watt generator for my initial power source but plan on...
I think he cost of the panel and breakers would be the cheapest thing on your list. Your 4100 watt genny is tiny for a whole house, and if you are planning on a solar set up, you will need to convert to dc, so, I take it your 4100 genny is used to charge the battery bank? Then the panel will not need to be anything but a small disconnect for the genny, basically one of those things that prevents the current from flowing back into the source, which you don't have. I would talk to the building dept., they may not want to take liability, and make you get a contractor to figure something out. All your appliances, and lights will be 12 volt, most motors are 12 volt anyway, they are just transformed to 12 volt from 110 current, and I don't think you will need breakers for 12 volt stuff. You could look at some camper supplies, boat stuff, they all run 12 volt appliances, and lights.
Feb 12, 2010 | Your One Source Homeline Load Center, 200...
Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
Dec 19, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Propane-converted generator sometimes sputters out and dies
I believe the problem may be with the propane. Have him call his propane provider and get them involved. good luck
Dec 26, 2008 | Coleman Powermate Premium Plus 6250W...
Pls i need an answer
Solar panels come in different ranges of wattages.Add up the wattage of different solar panels you get e.g. Ten 100W solar panels will give you a 1Kw solar system.
Jul 11, 2008 | Sun (PEX75030) 15-Watt Power Supply
Electrical Supplies Logo
105 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
