Question about LG WM1814CW Front Load Washer
How do I put hose back in behind lower cover cap? pulled completely out when attempting to drain hose & clean the pump filter.
Find water leaking periodically left side center to front, not sure where is from - usually clean pump filter & stops awhile
    Problem Solver:
  • 14 Answers
Go to www.youtube.com and enter
LG WM1814CW
Into search bar on youtube.
You will see various videos on How To Fix your exact model washing machine. :) x
Posted on Nov 18, 2014
2 Suggested Answers
  • 10 Answers
SOURCE: My LG Washing Machine WM2277 has an object stuck just behind the drain pump filter, causing water to leak underneath the machine. How can I remove the drain pump filter.
Check the booklet for instruction it should be easy
Posted on Oct 15, 2012
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
NOT POMPIN WATER OUT.I CAN HEAR POMP GOING BUT NOTHING HAPPENS
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 29, 2011 | GE Nautilus 24" Built-in Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
I have a bosh washing machine WFO2462 and my problem is that: washing solution does not completely drain. I have cleaned the pump several times but the problem still remains and every time I want to use...
I believe that it's on the front bottom right side of the machine. Press the tab down and open the little door and you'll see a hose and a circular cover. You need to place a little towel on the floor and a shallow pan. Pull the drain hose out just about 6 inches and pull off the end plug. This will drain the remaining water in the washer. Put the cap back on the hose and tuck it back into place. Unscrew the round cover and pull which will be the filter. Should be clogged and rinse out the filter at the faucet and reinstall. That should do the trick.
Apr 21, 2017 | Washing Machines
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
Do I need to clean the filter behind the lower front panel? I removed the panel but nothing in the owners manual that describes it. I heard that you need to do this every year or so for general...
Remove the lower kick plate. Unscrew the two screws holding the kick plate in place, and gently pull off to remove. The kick plate is the lower outside cover of the washing machine.
Place a small bucket under the white hose. Remove the cap on the white hose by untwisting it. Allow any remaining water in the hose to drain into the small bucket. There shouldn't be much water, but there can be some.
Look inside the white hose. Remove any visible obstructions or lint.
Look inside the hose cap. This is where the lint filter is. Remove any visible lint with your fingers. Rinse the hose cap under warm water to remove any remaining lint.
Twist the cap back onto the white hose. Put the kick plate back in place. Screw back on.
Oct 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F 02
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(Actual drain filter location and procedure below)
• If the above does not correct the problem replace the pump
How to Check your drain pump filter for foreign objects:
Most likely, this issue will be the cause of a clogged drain filter. Use my procedure below to help locate and clean this filter.
First, you will need to unplug your unit and shut off the rear water faucets that feed the unit.The pump has a clean out filter located at the front, behind the lower section of the front panel, that allows for the removal of large objects that may have passed from the basket. You will need to remove the front panel to access this large object filter device. Now, Once you have located the drain filter cap; Push twits and pull out the filter cap that is visible. Clear out any debris and wipe the filter and the surrounding area with a mild detergent. If needed, wear gloves and use vinegar or bleach to remove odors, mold and mildew. Rinse the parts completely, if possible. Next; Remove the drain hose and clean it with a mild detergent or warm water. If necessary, again use vinegar or bleach to remove odors and mildew. Completely purge this hose. Once the drain hose has been purged, Reconnect the drain hose and filter. Next; Place the front panel back on the unit. Reconnect the inlet hoses and plug in the unit and turn it back on for a test run. If the cleansing dose not produce positive results, replace the drain pump.
Click here to access service manual for your unit. The actual component access procedures dealing with this issue will be on page 3-10 in the manual provided under the title"PUMP MOTOR". Front door and panel removal procedures are also described in this manual. This will start on page 4-1. Foucuse on pages 4-3 and 4-4 for front panel removal to access the drain pump and filter assembly.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG WM1814CW Front Load Washer Logo
78 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
