Question about HP LaserJet Office Equipment & Supplies
My printer hp laser jet pro 400 mfp475dn shows error 57.02
What does error 57.02 mean?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 884 Answers
Hi
I have taken this directly from the User Guide
"57 Fan error Turn off then on
Description - The product has experienced a problem with its internal fan.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
If the message persists, contact HP support."
For future reference this manual can be found here:
http://h20565.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c02966093
and being in pdf format can be saved to the computer.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 17, 2014
  • 327 Answers
SOURCE: hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
Posted on Dec 15, 2008
ginko
  • 19396 Answers
SOURCE: is HP Laser Jet 2420n
Duplex on this printer is manual, that means that you will have to re-insert the paper by yourself.
This if you have the 2420n, the 2420dn instead is the duplex model.
Here specifications, look where it says duplex, 2420n had only manual duplex (the printer wait for you to re-insert page).
Posted on Feb 17, 2009
pdouglasss
  • 125 Answers
SOURCE: error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
Posted on May 24, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
  • 6 Answers
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
Hp laser jet pro 400 m401 printer 59.A0 error
SOURCE:HP color laser jet printer is displaying error
Developing disengaging motor error. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow
above steps if problem not resolved then call hp engr for 4th step.
I Hope It Works.
Sep 15, 2017 | HP Office Equipment & Supplies
did you read the HP page, on your M401 page.
and read the trouble shooting guide there,
all error codes are there, to read 24./7.
or ask here and they will point to the page. for you.
https://h30434.www3.hp.com/
Jun 19, 2017 | HP Office Equipment & Supplies
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
Hp laser jet 300/400 10.1000error
10.10 error means it does not recognize the chip on the cartridge or that the seal is still in cartridge need new cartridge
Feb 24, 2015 | HP LaserJet Pro 400 color M451dn - Printer...
Hp leserjet pro 400 mfp scaner error 52
The scanner initialization did not pass it seems. Try cleaning the glass and white background.
If that doesn't work, the scanner bulb may be faulty - try replacing it.
Sep 09, 2014 | HP Laserjet Pro 400 Mfp M425dn...
Hp leserjet pro 400 scner error 52
The printing scanner (laser) has likely failed. HP has had some issues with the series of products and bad laser scanners so you may want to contact their customer service to see if you can get it fixed under warranty.
My printer hp laser pro 400 show message 50.3 fuser error
hello ,,
50.x Fuser Error
Description
The product has experienced an error with the fuser.
Recommended action
Turn off the product, wait at least 25 minutes, and then turn on the product.
Oct 21, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
624 people viewed this question
Seeker5211
Seeker5211
