I came home from a weekend away and the HW works fine but the heating won't fire. when I try the times turns it self off and back on. but no heating. if I move the heating to constant it just
I came home from a weekend away and the HW works fine but the heating won't fire. when I try the times turns it self off and back on. but no heating. if I move the heating to constant it just keeps going through the loop. On then off ect
  • 9,639 Answers
Try replacing the batteries in the thermostat. If there are none to replace then the problem is inside the heater.
Posted on Nov 17, 2014
Please,tell me how do I turn off my self timer on my JVC micro component UX-lp5
Press CLOCK/TIMER repeatedly to select "DAILY 1", "DAILY 2", or "DAILY 3", then press CANCEL. See page 2 of this manual.
Mar 27, 2013 | Audio Players & Recorders
My 1994 Jeep Grand Cherokee won't start. It turns over but won't ignite or stay running. It was running fine until I filled up with gas and was driving home. I've tried to reset the security system wi
The gas u put I'm the tank was high octain if it was it was making the engine fire to early replace the gas and it should wor properly
Feb 16, 2013 | Cars & Trucks
P0411 secondary air injection incorrect flow on porsche boxster 1998
You have a code to go by & you know codes are
used to diagnose the systems with the fault
It won't go away by it's self & running fine to you
is no guarantee that it will for long or not cause damage
Get it repaired
You can use the internet to research codes & their causes
Nov 13, 2012 | 1998 Porsche Boxster
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
My clean filter light won't go off on my frigidaire & my dryer won't turn on
Did you try to remove the back cover after unplugiging your dryer ,to find a lot of lint in the back of the dryer? Some times you may have to clean in this area for fire safety. Maybe this would sold your problem.
Jul 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Any idea why it takes a few turns of the key to start my truck? There is 59000 miles on it and the last 2 mornings the truck did not want to turn over. it eventually did, and would start fine in the work...
You have to be specific about the engine turning over
That is done by the starter circuit
Some people call that cranking
Some people also say it won't crank, when they mean
it does crank, but won't start
Not turn over the engine -----
Old & Weak Battery
Dirty Battery Cables
Worn out Starter Solenoid -- you can buy & replace
without getting the entire starter
A bad Starter
Sep 22, 2011 | 2007 Lincoln Navigator Ultimate 4x4
Just bought a self propelled toro, model #120000. Used it last weekend and tried to use it again this weekend. The self propelling part isn't working. There's a bit of a grinding sound, but it...
It is possible that the scews and/or latches for the cover will be accesible UNDER the deck where the blade it. Have someone tilt it back while you check and/or hold it for you while you removes the retainers and screws. If the unit IS defective, I suggest you take it back as the Toro should be warranted.
Sep 11, 2011 | Toro Power Lawn Mower
My iphone is hanged its shows apple logo only, hw can i solved this problem without loosing my all data,like my videos,contacts,pictures,pls help me out
Try pressing and holding both the POWER & the HOME button at the same time for around 3 to 10 seconds until it turns OFF. Then turn it back on again.
If it still won't go past the Apple logo, use tinyumbrella to Fix Recovery or to Exit out of Recovery. Download tinyumbrella using the links below: for Mac for PC (Windows)
Update tinyumbrella first if it tells you that there's newer version available.
NOTE: Your computer must be able to recognize your iPhone before you can use tinyumbrella to fix it. If your computer could not recognize your iPhone, you first need to put it to DFU mode. To learn more about DFU mode, CLICK HERE.
If those things still don't work, you'll have no other choice but to restore. Again, your computer must be able to recognize your iPhone before you can restore it using iTunes. Put it to DFU mode if your computer won't recognize it.
Read more tips for iPhone, iPad and iPod touch, CLICK HERE.
Apr 25, 2011 | Apple iPhone 3G
Everthing kicks on just fine but burners will not fire or fire and turn off. Wired around the high level sensor and it worked fine. The weekend beofre it worked fine. Seems odd possibly the high level...
Hi, I will keep this short as you have solved this already. If you have bypassed a sensor, or any kind of safety switch to get heat, this is the faulty part. If it is working fine bypassed, you need to replace it as it is faulty. You are jumping across the contacts, so pick up a new one. Please don't leave it bypassed for long, just until you get a new one. Good luck to you, and good job!
Shastalaker7
A/C, & Heating Contractor
Please don't forget to rate me!
Nov 19, 2010 | Dayton Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
