Question about Kitchen Ranges
We have stove richmond 1000DFT champagne. Lower electric oven is tripping the fuse switch. Leave it a while-comes back on. Please advise.
Presume some new part is needed
SOURCE: frigidaire es300
you could have a power problem.. the stove will still work with half the power..like the burners on top will work. if thats not it. the wirers could be crossed or you may have a thermal cutout thats bad. but when the tco is bad broil and bake should not be working.. hope this helps
Posted on May 15, 2008
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
beachin
  • 6 Answers
SOURCE: GE Profile Electric Stove - Buttons for oven don't work
We had a bunch of storms roll through the area and we figured a surge must have fried our control panel. We decided to buy a new oven rather than spend $200 fixing this one. Luckily, our local Sears rep wasn't in it just for the commission and suggested we flip the circuit breaker off for 10 minutes to allow the range to reset itself. Works good as new! So, try this first before you make a decision. Good luck!
Posted on Apr 03, 2009
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
Bought a prima superchef oven, when I plug it in the electricity trip switch cuts off the power.
or a wire is touching the casing. If it is new, call the retailer. If it is secondhand call an appliance technician.
If it is a UK or Australian cooker, and the wires a fixed into terminals behind a cover on the wall, you have it wired wrong.
Big volts and amps can kill.
http://www.askmediy.com/wiring-diagram-for-a-stove-plug/
wiring diagram for stove plug AskmeDIY
Aug 21, 2016 | Ovens
Oven wont come on
Check if plates work. Assuming it is a stove. If they don't then supply turned off or main fuse tripped/melted. If they work, and oven has upper and lower element, turn on each individually. If one works and the other does not, then the cold element is probably open circuit. If neither works, then the oven fuse tripped/melted. It can be that the oven switch is faulty, especially if the oven is old, but that would be the exception, not the norm. If this procedure does not help then you need a multimeter to do some measurements - not for the regular person. If it is just an oven on it's own, check supply or fuse. Further you would need to do some measurements with a meter!
Oct 29, 2013 | Bosch Ovens
Electric stove
Check the thermal coupler a copper thermometer for your stove after checking all the fuses in stove and circuit breaker box of house to see if any have tripped. Circuit Breakers should have the switches all in a line. Any not in the lie will be tripped. Fuses in your stove are usually in the top part of the stove where the instruments are and fuses screw out and visually are easy to detect if they are blown or not. Remember all ways Unplug what you are working on to prevent shock
Jul 03, 2013 | Ovens
I've a stoves efa600h electric oven and grill, and it's stopped working! It will switch on, and start up even as normal, but then after not very long (not long enough to cook oven chips) it's as if all...
There seems to be an overload switch in the stove and that is tripping out and resetting after the 10 minute interval. You need to find out if the overload switch is faulty and tripping out at a lower load, which is the more likely scenario, or if the stove is really overloading the switch. A snap amp meter around one of the cables will give you the stove current draw. Probab;y easier than doing that will be to replace the switch and see if that fixes the problem.
Feb 06, 2011 | Stoves Newhome ECH600MXa Electric Kitchen...
My ge stove is dead. control panel is out, burners and oven will not turn on
The circuit breaker probably tripped. Usually it will be a 2 pole 40 or 50 amp breaker. Turn it all the way OFF, then back ON. Sometimes it's not easy to visually tell if a breaker has tripped, so do it anyway. If that doen't solve the problem post back please.
Dec 18, 2010 | General Electric Stove/Oven/Range Chrome...
Stoves richmond 1000df - no instructions for which knob operates which oven - dont know how to use slow oven
The book that came with the cooker only explains the symbols on the knobs not which knob to use with what cooker. It is very confusing. Does anyone know where I can get something more comprehensive?
May 14, 2010 | Stoves Richmond RM1000DF Dual Fuel...
Hygena oven trips main fuse box when switched on
sounds like that element is getting a "hot spot",high resistance area, will oven operate w/o that element in place?you also could have a bare wire touching the oven case somewhere, if it trips w/o having anything turned on remove back cover and examine all wires and connections
Aug 14, 2009 | GE Spectra JBP78 Electric Kitchen Range
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
