Need a code for a PROSCAN PLED1960A-F tv to enter into a Cox Cable universal remote control
Call COX...They know them all! 760-599-6060 Go through the phone menu amd wait for tech support for cable tv
Posted on Nov 29, 2014
aprmaejun
  • 97 Answers
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
SOURCE: I have a tevion remote. I need the code for TCL TV
lost my instructions can't program it
Posted on Jun 01, 2009
  • 144 Answers
SOURCE: RCA universal remote codes
Try this link below that leads directly to RCA and their universal remote controls.
Good luck, CBR2009
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_UNIVERSAL_REMOTES
Posted on Jul 11, 2009
SOURCE: remote code for Sabre TV on Cox Universal Remote
I had the same problem and I found out that the philips universal remote works! What you will do is follow the instructions in the book and your channel will change to the same channel. The instructions are: Hold the select button for about three seconds and click the TV button. After this you will hit the channel button until the channel on the TV appears in the upper right hand corner. After this you will hold the mute button for about 3 seconds and the release. This should work! Hope this helps you out!!!
Posted on Nov 07, 2009
  • 25 Answers
SOURCE: sylvania LC321SS9 remote code
I have the sylvania LC321SS9 tv and a atlas dvr1056 remote code 1864 works great with all functions!
Posted on Dec 10, 2009
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Electrohelponline
Nov 17, 2014 | Televison & Video
None of the Proscan TV codes I have work In My COX universal remote
Than the COX universal remote dose not work with the Proscan tv.Try website like Remotes.com to buy the same exact to the original Proscan tv remote.
Oct 18, 2010 | Proscan 32LA30Q Television
Need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
  1. More results from www.cox.com »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ...
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | eHow.com How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ...
    www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
Jun 01, 2009 | Kenwood Audio Players & Recorders
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Feb 17, 2009 | Proscan 32LA30Q Television
LC321SS9 remote code and cox remote can not find universal code
I have the same TV and the same problem. I exchanged the Cable remote for a new one and did the auto search. (hold the tv button/Sel key then channel up key) It worked with the new remote. I believe the code is 121
Jan 14, 2009 | Zenith ZEN450 Remote Control
I NEED THE CODES FOR VIZIO LCD TVS
https://www.cox.com/content/dam/cox/residential/support/tv/print_media/m7810_user_guide.pdf
This manual might work for your remote. It does not have codes for Vizio either but does have the procedure for Finding codes not listed on PAGE 20. Go through that procedure which can find codes that will work.
Jan 20, 2018 | Televison & Video
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
