Question about Bella 13600 Coffee Maker, 12 Cup
How do I set timer
Coffee maker will not make coffee when water is added,I push on button and it wont come on
    Problem Solver:
  • 9 Answers
Run a descaler in the pot, CLR , , vinegar or lemon juice also god , let it stand for whole day with it , clean and only use distiled water from now on , now it will work like a charm .
Posted on Nov 17, 2014
One side of this coffee maker has a timer problem. When we push the brew button it clicks but dispenses no water. If we hold the brew button down it clicks continually and rapidly and despenses water...
Is it possible that the programming on the board is defective. Try reprogramming the side before replacing the board, then set the lock on the board and test the brewer.
Jun 13, 2011 | Bunn Dual® (20900.0011)
WE HAVE A BUNN VLPF SERIES COFFEE MAKER. WHEN YOU PUSH THE BUTTON TO MAKE A POT OF COFFEE, THE WATER DOESNT STOP AT ONE POT IT MAKES 6-7 BEFORE IT STOPS. IF YOU TURN OFF THE MACHINE WHEN THE DECANTER IS...
Sounds like your timer part #32400.0002.This is the new type timer which replaces the dial timer.Another thing is does this happen when you turn on the on/off switch? I would also check your liquid level probe in top of tank.Always a possibility bad liquid level board.If it only does this when you push the brew button the timer is bad.
Feb 07, 2011 | Bunn VLPF Coffee Maker
The coffee will go all over the counter. We did not get a manual with the coffee maker. Could I possibly be setting the pot incorrectly on the plate?
Check the following:
1. Make sure that you are using the correct size coffee filter in the basket. Only one filter is needed to allow proper drainage.
2. Check the spring loaded button on the bottom of the coffee basket. Remove the basket, put some water in the basket, push the button up to make sure the water is released from the basket.
3. Put the basket back in place, insert the carafe and check to make sure that the top of the carafe cover pushes up the button on the basket to release brewing coffee.
If all these check out, then there is an internal leak and the unit need to be repaired or replaced.
Aug 11, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Machine wont make coffeee, m,essage says ventilate...
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 20, 2010 | Saeco Stratos Coffee Maker, Espresso...
How does the pot make strong or reg. coffee by pressing a botton not adding coffee amount ?
By pressing the button for "stronger" coffee, it slows down the rate at which the water enters the grounds. This allows the water to set in the grounds longer and therefore can make the coffee a bit stronger. This is why on some pots when there is a 4 cup setting used, it takes longer for the coffee to be made. With such a small amount of coffee, it should go thru more slowly to get the same result.
Mar 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I need an instruction booklet to set the timer for the coffee.
Go to Hamilton Beach dot com, pull down customer suppot menu, click on use and care guides, type in product and model number, click send and your manual will load. Print it out so you have it. Setting the timer is a piece of cake, Hold down the program button until the clock flashes. While still holding the program button down, set the timer for whatever time you want the pot to perk. Let go of the program button. To check if the timer is set right right, puch the prigram button just long enough to see what time it is set for. If it's right, prepare the pot the night before, push the program button to set and forget about it. It will perk at the time you set every morning. Katherine
Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Need help on using Timer feature on Melitta Mill & Brew
My second one just died, and I am very sad, but I can help you with your question.
First you have to set the time. Do that by pressing the hour or minute buttons until the time blinks. Then you can press the buttons to set the time. AM/PM are differiented by a red dot coming on in the time display. You can set that as preferred.
To set the timer feature, press the time button until the time blinks. Then use the hr and min button to set your timer setting. Pay careful attention to match the am/pm button with what you want.- if you don't you will be 12 hour off. To use the delay, set up the coffee pot, then push time. The red time indicator will light. If you are using ground coffee press the mill button. If it is lit, the mill will not turn on. This goes for either timed brewing or present tense brewing.
THe coffee pot has a timer - it will shut itself off after 1 hour. If you want to restart it, just push the mill button and press the on/off button.
Mar 15, 2009 | Salton Melitta Coffee Maker 10 Cup - white...
Our Bunn A10 Coffe Maker has no brew timer on the left side. How can we adjust the coffe maker so that we can get a full pot?
Hello. I need to know if you have an automatic unit, or a pourover. The pourover will not have a timer at all. The difference is you have to pour the water in to get coffee out, an automatic would be connected to a water line, and you just push a start button. If it is an automatic unit, there has to be a timer somewhere to adjust the amount. Here is a web address that has your manual, and a parts breakdown should you need to find where the timer is located.
http://www.bunnomatic.com/pdfs/commercial/manuals/29079.0000.pdf
Hope that helped, and thank you.
Mar 05, 2009 | Bunn A10 Coffee Maker
Setting the clock on my coffee maker
After turning the coffee maker on press and hold down the timer button until flashing; then press the hour and minute buttons to set the clock.
Dec 19, 2008 | Cook's Essentials Cooks Essentials Arome...
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
Bella 13600 Coffee Maker, 12 Cup Logo
203 people viewed this question
Top Bella Coffee Makers & Espresso Machines Experts
John mullen
Pieter Vleeshouwers
Pieter Vleeshouwers
Kolbrun...
Are you a Bella Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
