I don't have a circuit diagram to refer. The IC used in this board is M51164L.
Check the stereo Balance control. If it is set to one end, that speaker won't output sound. If found the setting to this is set to mid-point, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
SOURCE: Sound proplem
its the audio amp, its fried and needs to be replaced. match the numbers up and purchase/replace boards, this will solve your problem.
SOURCE: I have a problem of
Vertical IC is a Flat IC with 6 to 12 pins mounted on a heat sink near the yoke plug................. Larry
Testimonial: "I have the vertical IC ( 7pins ) and the problem solved . Thanks for your useful advice . "
I need some tips from an expert in Sanyo Tape recorders.
