Question about LG enV2 EnV-2 VX-9100 VX9100 Premium Pink Magenta Silicone Rubber Skin Case Cover
My phone no longer vibrates.
The vibration mode has stopped working.
    Habit-Forming:
  • 155 Answers
Try this.
Disable vibration.
Turn phone off.
Remove battery.
Wait at least 30 minutes.
Put battery back on the phone and turn vibration on.
Good luck
Posted on Nov 17, 2014
The vibrate mode on my phone will not work
Go to phone app, dial the following number-
*#0*#
You will get a screen with following options (Not All)
Click on Vibrations as shown above. If the phone vibrates, then there is some issue with Settings or Software. Restart or Reset should help you. Of it doesn't vibrates, time to visit the service center.
How to Fix Vibrate not working on my phone
Good Luck :)
Sours- How to Fix Vibrate not working on my phone
Feb 20, 2016 | Samsung Galaxy S6 Edge
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
Phone is stuck in silent mode
Press and hold the pound key (#) until it exits silent mode.
Here is the original text from the manual of the phone:
"Quickly Switching to Silent Mode
phone from making noise, in a theater for example.
In Idle mode, press and hold the "#" key until the “Silent
Mode” message and the Vibration icon display...
To exit and reactivate the previous sound settings, press
and hold the # key again until “Exit Silent Mode” appears.
The Vibration icon no longer displays."
You can also download the pdf file for the phone's manual online by simply googling "Samsung x427m pdf manual."
Hope this helps!
Mar 13, 2010 | Samsung X427M Cellular Phone
Vibrate stopped working
Pls check your battery power if it has gone out. If the battery has gone out then phone might not be able to draw enough power from it when vibration mode is on.
Jul 22, 2009 | LG Dare VX9700 Cell Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
My samsung hue will no longer vibrate but the ringer still works occasionally it will vibrate what can i do to fix this
Ok, the vibrating mechanism inside the phone will need to be replaced. this mech will stop completely soon. this repair will have to be initiated by a samsung service tech. You may be able to take this phone in for a local repair at your local cell phone providers retail outlet.
Jun 05, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Motorolla Razer V3i Keypad is not working
sir it is hardware problem because of vibration it damaged
Jun 02, 2009 | Motorola Mobility RAZR V3
My LG Env stopped vibrating on inbound texts
Make sure you go in settings and somewhere either under Profiles or Settings you should be able to make it vibrate. Or if there is a volume rocker on the side of the phone(usually two buttons with arrows, one pointing up and one pointing down) just use those and set it to vibrate. Hope I Helped!
Jan 28, 2009 | LG enV VX9900 Cellular Phone
Motorola krzr k1m stuck on vibrate
So my girlfriends phone wouldn't stop vibrating either...so I just threw it on the carpeted floor (throw it somewhat hard, obviously not hard enough to break it).....then the vibrating stopped.....worth a shot I guess if you don't want to go through the hassle of sending it in.
Feb 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
LG enV2 EnV-2 VX-9100 VX9100 Premium Pink Magenta Silicone Rubber Skin Case Cover Logo
64 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
