Question about Frigidaire Refrigerators
I have a new Frigidaire refrigerator with water dispenser on outside that I haven't had hooked up yet. What happens if I don't get it hooked up for about 2 more weeks, can any damage
Just purchased and didn't get the water line hooked up yet, is this a problem?
  • 615 Answers
No.
Posted on Nov 17, 2014
  • 56 Answers
SOURCE: Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
Posted on May 27, 2009
SOURCE: Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Posted on Jul 02, 2010
richroth
  • 9472 Answers
SOURCE: I have a side by
Check to see if your refrigerator's filter has a blockage in the filter cartridge. Remove the water filter cartridge supplied with the refrigerator. If it has not been replaced in the past year replace it with this part. Here is a video to walk you thru replacing the filter.
Posted on Dec 05, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Whirlpool side
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Posted on Jun 01, 2011
  • 8 Answers
SOURCE: I have an Amana Side by Side Refrigerator with an icemaker and water dispenser. I don't have a water line to hook up to the refrigerator. Is there an on/off switch for the icemaker?
There should be a stop control near the icemaker where it collects ice in the tray. It should be an L-shaped lever. move it to the stop position.
Posted on Oct 03, 2012
Hooked my new Frigidaire gallery edition refrigerator water then power. Let it run for about twenty minutes! Tried to purge water, display went black dispenser light stayed on.
Dispensers are not made to stay on that long. (2 minutes) You may have burned out the dispenser coil but it should not be related to the display going blank unless of course the twenty minutes also burned out the low voltage and the relay that controls the water valves that is on the control board.
APPLIANCE 911
Dec 10, 2015 | Frigidaire Refrigerators
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Frigidaire water dispenser won't work with new filter
The dispenser has a dual water control valves that control ice maker water and dispenser water. To find your parts you will need your refrigerators model number most time found around the fresh food sections door. Below I have a tutorial that may help you determine what may be the problem with dispensing water. Hope this helps, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire Refrigerators
Oct 02, 2012 | Amana Refrigerators
Water & ice dispenser don't work
The button lock switch along with the other switches on the door use one common return wire for power to the solenoids. The freezer door light switch will stop power to the buttons if it has failed.
Jul 08, 2012 | Frigidaire PHSC239DSB Side by Side...
Feigidaire side by side refrigerator keeps getting
Your dispenser door is possibly not closing properly. Also you may have a seal leak around the door When either of these happen the air from outside is drawn in and freezes on the surfaces tat are coldest, Thanks, Sea Breeze
Aug 28, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
66 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
