Question about Victor 0781-0027 SR 250C-540 Oxygen 4-80 PSIG
<!-- from fixya rte -->HOW DO YOU REBUILD A VICTOR SR250C REG - Victor 0781-0027 SR 250C-540 Oxygen 4-80 PSIG
Why did Gus kill Victor?
There are two likely reasons:First, Victor was seen by witnesses at Gale Boetticher's crime scene. Gus being an extremely cautious man, thought it best to dispose of Victor to avoid him getting picked up by the police. A second reason which ties into the first; Gus killed Victor in front of Walt and Jesse to show that he was willing to kill a loyal member of his organization for a minor screw-up, what chance do Walt and Jesse have after their betrayal? Alternatively, In season 5, Walt theorizes that Gus killed Victor because he "Flew too close to the sun and got his throat slit.". Meaning that Victor started learning the process or cooking meth on his own by watching Walt and Jesse and in a sense, stealing the secret recipe. However, this was more Walt's wishful thinking as he was angry with Mike's attitude towards him. Lastly, it's possible that Gus suspected that Victor had been stealing the meth Jesse had been skimming from their shipments and giving to Badger and Skinny Pete.
Sep 04, 2016 | Breaking Bad (2008)
VICTOR PHONOGRAPH VVIV251106E, WHAT YEAR WAS IT MANUFACTURED?
The IV was Victor's lowest priced model for many years. Production was started in September of 1911. Full production was discontinued in early 1924; however VV-IV's were still being assembled and shipped in low volumes as late as the spring of 1926.
the previous was copied from the link below, the 2nd link gives more info on victors.
http://www.victor-victrola.com/IV.htm
Oct 20, 2014 | Audio Players & Recorders
Need head gasket for vauxhall victor 3300 6 cylinder where can I find them
overhaul kits are available from reputable auto spares shops, engine rebuilding shops and from the spare parts department of you local dealer. If you buy on line ,be careful as some generic gaskets do not have all the coolant holes to allow water to flow from the block to the head
Oct 01, 2014 | Vauxhall Vectra Cars & Trucks
Need help rebuilding a Victor torch body
Never found any place that does that
Once I dropped one off at a long time welding
supply & they media blasted it outside for no reason
& it looked bad & the valves were never replaced
Mar 07, 2013 | Cars & Trucks
Victor cga 540 oxy reg. hi side 2000. lo side climbs to max and pop off releases. can adj for short then climbs and releases at pop off
take it to the nearest weld shop, its defective, gages, do one thing, keep pressure where you put it, there is a spring inside and it can get weak by leaving it turned in,
please, take it to a shop, before it fails.
Mar 03, 2011 | Victor CSR350D Oxygen Regulator
Acytelene regulator pulsates when welding or cutting
the gauge needs rebuilding the diafram is leaking inside
Aug 27, 2010 | Victor ST900FC Straight Cutting Torch...
Need parts for victor 272654 oxy reg
I will sell exterior parts only,I do sell internal regulator parts but only to certified technicians that have the test equip and can re-certify the gauges after a re-build
Jul 27, 2010 | Victor Welding Tools
I would like to know if i can dismantle the cutting torch,to change some parts on it
It is not recommended. Most shops won't even work on their own. Take it to you local welding shop and have them send it in for rebuild for you. Don't risk starting a fire or injuring yourself. Not worth it.
Jun 19, 2010 | Victor ST900FC Straight Cutting Torch...
How to separate the conrod and crank to get the piston out of a v
If you have removed the retainer rings, then use a deep socket that is smaller than the wrist pin, and use it for a punch and it should tap out with a mallet
Mar 22, 2009 | Garden
Victor 0781-0027 SR 250C-540 Oxygen 4-80 PSIG Logo
561 people viewed this question
Top Victor Home Experts
Donni Steen
Tom Chichester
Are you a Victor Home Expert? Answer questions, earn points and help others
