Question about Ovens
Hi I have a AE6BSS single built in oven from b&q. The control knob has been broken off, can I replace it and if so where do I get the part I need? Thanks
  • 2,374 Answers
Try repairclinic.com among others online.
Posted on Nov 26, 2014
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Posted on Nov 17, 2008
  • 1253 Answers
SOURCE: Hi, I have a single built in oven and it does not
http://www.neff.co.uk/ovens.html
Here is the web site for Neff. Surf this site and see if you can find you specific unit. Need model and sometime the serial numbers.
Good luck and hope this gets it done for you.
Posted on Oct 24, 2009
  • 417 Answers
SOURCE: hi i have a Stainless
It will most likely be a faulty oven heating element causing an earth fault which trips the breaker.
You will need to have a replacement element fitted.
Posted on Dec 11, 2010
SOURCE: both oven knobs have come off and although don't appear to be broken we can't seem to fix them back on properly
First try a layer of silver paper around spindle.
If not satisfactory then try a "No nails" type of clue.
Posted on Jun 04, 2012
Control knobs
Hi, Elan oven has seemed to drop off the earth right now but I have some feelers out trying to get parts for it. If you have a manual there may be a # in there to call. The oven itself may have a phone number or a company name to call for information on parts. The best way to fix your problem would be to replace the knobs with new ones. You may be able to take the ones you have to a parts place and they may have something to at least work temp until you get new ones. I will continue to work on finding parts for it so If you find anything or have any information to help me find them, Let me know. Hope I can help. kstfas
Sep 19, 2007 | Elan E-948-DB / E-948-DW / E-948-DS...
Both oven knobs have come off and although don't appear to be broken we can't seem to fix them back on properly
Jun 04, 2012 | New World E90DOa Electric Double Oven
I need to remove the control panel to replace the Function Selector (knob) how do I remove the panel? Thanks
HI
you dont need to remove panel to replace, it literally just pulls out from the front as a complete assembly you may find using the edge of a teaspoon helps to draw it forward without marking the steel use the curved bowl of the spoon against the steel.
if the knob is damaged from heat escaping (melted) make sure you grill with the door closed.
Feb 22, 2011 | Neff B1421 Electric Single Oven
The stem/shaft that holds the oven knob seems to be broken--the knob turns but does not turn the shaft. Is this a repair an amateur can do and what part do I need?
first pull the knob off the shaft and check to see if its broken where the shaft is supposed to lock-in if so u jus need a new knob. if not you have to pull the panel off the stove and replace the shaft this shouldnt be too difficult either way.
Jan 24, 2011 | Viking 27" Professional Select Built-in...
Hi i have a Stainless Steel AE6BSS Single Built In Electric Oven from argos, everytime i put oven on above 120 it trips all electric down stairs does anyone know what this problem could be thankyou
Dec 11, 2010 | Ovens
I need replacement control knobs for my hob-can
In your browser bar type in-------WWW.SERVICEFORCE.CO.UK.
Follow the links in the drop down menu, and you should be able to order the parts you require.
Please rate my solution.
Thanks.
Nov 07, 2009 | Zanussi ZBF360 Electric Single Oven
Fan control knob sheared off w/ part of stem... can i replace,if so which parts tks, mgw
You need to replace both the control knob and the switch it is located on.
Thanks.
Jul 16, 2009 | Jenn-Air JJW8530C Expressions Collection...
Maytag oven calibration
Maytag single built in oven model cwe9000bcb beeps intermittenly. Reset stops for about 1 minute. Two control panel boards replaced since 2002 with same problem. Can it be fixed?
Dec 18, 2007 | Maytag CWE4800A Electric Single Oven
Ovens Logo
75 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
