Question about Moen Kingsley Two Handle Roman Tub Faucet With Rough-In Valve ....
Water in tub is only hot for a few seconds and then turns lukewarm. We have hot water everywhere else.
We switched the cartridges from cold to hot and vice versa but didn't see any change. What could be causing this?
  • 615 Answers
Check this link: http://www.selfhelpandmore.com/plumbing/how-to-adjust-a-single-lever-shower-faucet.php
Posted on Nov 17, 2014
dragonsthatk
  • 547 Answers
SOURCE: Not enough hot water, has to do with a shower valve
take off handle (screw under cap) there is a plastic peice behind for ajustment if you move it one way it allows more if you move the other way less contact me if you have problems thank you for useing fixya please rate me
Posted on Feb 21, 2009
snap101
  • 117 Answers
SOURCE: water will not turn off
are the handle extensions on the cartridges all the way. i know sometimes the moens are a pain after you put the trim on to get them on and seated right so it actually spins the cartridge. also check the cartridge alignment the cartridges have little white tabs on the sides that correspond with a slot in the valve body if they aren't aligned it won't shut off either
Posted on Jul 31, 2009
  • 94 Answers
SOURCE: water leaking from tub spout when shower is on
yes they do,part #1224
Posted on Apr 27, 2010
  • 20 Answers
SOURCE: Sensitive Temp adjustment through shower.
Pull the trim off of the valve and you will see a 1 inch diameter flat screw, unscrew that and clean it out and try it again. If rinsing it doesn't work you may need to replace it. It is called a balancing caulk.
Posted on May 02, 2010
  • 349 Answers
SOURCE: only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
Posted on May 03, 2010
Cold Pulses when set to HOT only
if you want only hot water, shut off the cold.. its only really used during the rinse anyway..
Feb 02, 2014 | GE Spacemaker Washer and Dryer Electric...
My shower only stays hot for a minute and then goes cold even though the hot water works everywhere else. I have a hot and cold tap and a third one to direct to shower or tub.
I would take a look at the stem replacement task. Maybe something is clogging the hot water flow, perhaps a damaged washer or debris
Jan 14, 2013 | Moen Home
SINGLE VALVE SHOWER FAUCET TURN ON TO GET HOT WATER ONLY GETTING WARM WATER LUKE THE OTHER TUB AND SINK FAUCET COME OUT HOT HELP PLEASE
I can think of a few possibilities. 1) Something is blocking the hot water in to the mixing valve. Fixing this would probably mean cutting out the valve (then redoing the water lines with a new valve (possible option)).
2) The hot water line is losing too much heat going to this second faucet. (If the two tubs are on different floors this is more common. Many places are plumbed with one line with Ts to all fixtures.) Insulating the water lines might help; alternatively an point of use water heater would help.
3) The hot water and the cold water in are reversed. (Test by leaving the water on full cold and full hot for a few minutes each.) If you get full hot when it should be cold, valves with a cartridge are easy to fix. Open the valve assembly, remove the cartridge and reinsert it after turning it around (side closest to you when you removed it goes in first). Otherwise, the incoming plumbing needs to be redone at the point where the cold and hot lines come into the shower.
I hope this helps.
Dec 15, 2010 | Price Pfister Home
Water it too cold adjusted all the way hot . folowed procedure and adjusted the temp regulator all the way hot but still runs lukewarm at best.
Turn off the water at the main shutoff valve and remove the cartridge. Soak it in white vinegar for an hour to remove any varnish deposits and make sure that the parts move freely - or just replace the cartridge. I'm assuming that you get hot water everywhere else and that the cutoffs (if installed) are open and that no lines are kinked. If you're the original owner of the faucet PF will send a new cartridge for free.
Apr 17, 2010 | Price Pfister R897EBK Brushed Nickel...
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Hot water comes out lukewarm
Pop out center of handle, and remove the screw from center, and remove handle. There should be a little nylon gear like sleeve that will pull out from center. Pull it out, and rotate it one way or the other, a little at a time, and slide it back in. Now just slide your handle on long enough to try it, no need to attach with screw yet until your done. May take a few tries to get it where you want it, then simply put handle back on, secure it with the screw, and snap cap back over screw.
Jan 05, 2010 | Moen & One Handle Tub & Shower Faucet
The hot water is not working at our tub. we had the water turned off for a couple months and I believe sediment is in the line. The hot water works everywhere except at this one tub. i need instructions on...
Your problem is most likely a bad cartridge.#1 turn off water in house #2 remove handle #3 you will see a horseshoe shaped clip that holds in cartridge remove clip and try to pull cartridge straight out you may need to purchase a moen cartridge removal tool for easier removal and install new cartridge and replace horseclip
Nov 14, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Wash cycle water is not hot for Speed Queen AWS53NW
Possibly a stupid answer..most water supplies at the hose connection have valves...turn off or at least reduce the amount of cold water with valve closed or partially open.
Apr 21, 2008 | Star Speed Queen AWS53NW 26" Top-Load...
Moen Kingsley Two Handle Roman Tub Faucet With Rough-In Valve .... Logo
129 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
