How to setup channels bush btu 160 btr no manual
How to setup programme how to setup programme no
    New Friend:
  • 3 Answers
Preess enter and ok
Posted on Nov 17, 2014
How do I tune in a Bush 32" TV,I need to put install programmes
Press the yellow button on the remote control to access the tuning/setup menu.
Aug 18, 2017 | Bush Televison & Video
How to program the channels
Check this link to download the user manual to your Sony TV. It has all details, with illustrations.
Sep 09, 2012 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Cant programme in remote to tv non of the codes seem to work
Do a code search method. If there is a code pre-programmed in the remote control, for your TV brand, you can get it by this method. If you fail, make sure that this remote control has no code for the said TV.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Sep 02, 2012 | Bush Industries IDLCD15W008HD LCD TV
ERROR MESSAGE RECEIVED FOR HARD DRIVE SAVED PROGRAM
your program getting virus infected so you install a one antivirus full verion update it and scan and try
May 30, 2012 | Panasonic Televison & Video
I need to set my all in one logic control with my bush telly but can't find the code to connect it?
If you can't find any setup codes, just try this method.
Code Search Method.
Apr 15, 2012 | Televison & Video
Will a 3.4 IR remote work in place of a 3.1 IR remote
It should work, provided has setup codes for your device. Check whether there is setup codes for the device do you want to programme with it. You can get this information from the code list of the remote control; you have purchased. If there is no code found, you can just search for a code.
Mar 30, 2012 | DISH Network IR Remote Control
I have no instruction manual for hitachi 32ld30ub
[PDF] 32LD30UB 32LD30UA - Hitachi European Service Sitewww.hitachiserviceeu.com/scripts/userguide.php/32LD30UB_EN.pdfFile Format: PDF/Adobe Acrobat - View as HTML
32LD30UB. GB. Instructions for use .... Electronic Programme Guide (EPG) .................... 20 .... Manual Channel Scan ............................29. Clear Service List (*) .THIS LINK ABOUT IS ALL YOUL NEED TO GET A FULL 58 PAGE INSTRUCTION MANUAL FOR YOUR SET, IV JUST AN HOUR AGO PRINTED THE SAME DOCUMENT MYSELF, HOPE YOU CAN GET YOUR PROBLEM SORTED NOW. X
Mar 26, 2011 | Hitachi Televison & Video
How do i tune my remote into my bush tv
Firstly you need the correct code for your television brand:
1037 or 0714 or 0037
Secondly, you need to programme the code into the remote control:
1. Press the relevant device key (e.g. TV)
2. Press and hold down the MAGIC (SETUP, or SET ) key until the light blinks twice (the light will blink once then twice)
3. Enter the code using the number keys (the light will blink twice)
Try one code at a time and test each one with various functions of the TV - Volume, Power, Channel, etc. If a code doesn't work or only partially works, try the next one.
This should be all you need to use your One-for-All remote with your bush TV.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | One For All URC 7740 Remote Control
Telex BTR-500 Instruction Manual
I have a manual I can fax to you if you are interested. Email me your fax number, or e-mail address and I'll scan it. Send to: diann_sells_slah@yahoo.com.
Jul 26, 2008 | Telex Btr-500 set (71208000sp) Wireless...
GE 20GT320 TV
don't use auto programme.
use manual or semi auto.
you have to press the auto programme button a few times.
Jul 12, 2008 | GE 25GT270 TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
