Question about Kitchen Appliances - Others
What does rapid flash of the harvest light indicate?
Machine will work fine up to 24 hours and then shut off with the harvest light blinking rapidly
  • howard thompson Nov 17, 2014
    Hi tom , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model number and what brand is it?
  • tom
    tom Nov 17, 2014
    It is mantiwoc qy0424a recently replaced curtain switch because it wouldn't open and caused the unit to shut off after 3 cycles and would give 2 blinks indicating to long of a harvest cycle. Ran fine for a week adjusted ice thickness and now it might work fine for two hours or 2 days and when I find it shut off the harvest light is blinking rapidly. I have not found this indicator in the literature for this machine.
    Master:
  • 571 Answers
Taking too much time to freeze. Usually a stuck water solenoid.
Posted on Dec 05, 2014
2 Suggested Answers
  • 112 Answers
SOURCE: I have a hoshizaki ice machine and it will
How long is a freeze cycle on your unit? How big are the cubes that it's dropping? The three beep error indicates that the unit exceeded maximum freeze time.
Posted on Dec 11, 2010
Why is the Rinse Cycle and Drying not working
Unfortunately you did not specify the model dishwasher so I'll give you a general answer.
(The indicator light, straight from Washing moves to completion stage where the light blinks rapidly) I believe you means the "End LED" (LED 3) blinks rapidly. If this is true and according to your description of failure (no drying, no rinsing) I think that appeared alarm AL04. It means the thermistor (NTC) not compliant - probable failure of the component that detects the temperature .
I suggest you to check: thermistor NTC, wiring and electronic.
24464652-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Rapidly flashing any combination of four LED diode means failure.
Dado
May 20, 2014 | Ariston Technologies Dishwashers
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
Grand prix front turn signals lights will not work but rears flash rapidly.
Definitely not the flasher, as long as it is flashing or blinking somewhere. Rapid flashing indicates a burned bulb, but since you already tried new bulbs in front, possibly bad bulb sockets, loose connectors, or a bad ground for the front bulbs. If you have a test light or voltmeter (multimeter), check for power at the socket when turns are on. If power then at the front, try new bulbs or trace the ground for those lights. If no power to the socket for turn signals, recheck wiring.
Apr 02, 2013 | 1995 Pontiac Grand Prix
Tachometer works sometimes and won't work others, plus the right turn bsignal blinks rapidly ; what is the cause and how to fix
Check the right indicator bulb either front or back wouldnot be working replace it it will work normal.
Jan 20, 2018 | 1997 Chrysler Sebring
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Interior lights flash on and off in windstar van
is the dome switch in the correct position it may also indicate a Trouble code is it a steady blink or a few blinks followed by a series of rapid blinks ....try lowering the intensity on the switch for the interior lights it may just be connecting enough to allow it to flash rapidly the door switch may be just opening and closing just enough to cause this an adjustment may be required to fix it does it happen if you hold the door switch in the fully closed position ?
Sep 07, 2009 | 2003 Ford Windstar
Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Jan 16, 2009 | Dwin TransVision 3 Plus Multimedia...
Program garage door opener
You must first erase what's in the memory.
1.) Simultaneously press both buttons 1 and 3 on the Audi's built-in remote. Hold them until the indicator light flashes (20 seconds or longer).
2.) Now hold your garage door remote close to the Audi remote.
3.) Simultaneously press and hold both your garage door remote button and the button you would like programmed. The indicator light will first flash slowly then rapidly.
4.) You may release both buttons once the light flashes rapidly.
Jul 01, 2008 | 2000 Audi A6
Kitchen Appliances - Others Logo
43 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
