Question about Barnes & Noble NOOK Tablet HD 8GB BNTV400
<!-- from fixya rte -->How do I remove the back of my nook? - Barnes & Noble NOOK Tablet HD 8GB BNTV400
    Sergeant:
  • 269 Answers
Posted on Nov 17, 2014
I removed some rarely used apps on my galaxy s6 nook tablet. Now I can't find my nook home app or my nook library
so you have deleted it by accident? Did you use the Search feature your phone must have somewhere?
Just redownload the apps again, then log in and redownload the library. If they are part of the operating system, try a Restore.
Jul 17, 2017 | Tablets & eReaders
How do I transfer my library on my old Nook to my new Nook?
How to transfer books from old nook to New Nook? Therefore, to transfer your Nook books to a new Nook, all you have to do is perform a synchronization between the Nook and your Barnes and Noble account. Press the "Power" button on your Nook and hold it down for two seconds to turn on the device. The Welcome screen opens.
How to Transfer Nook Books to a Different Nook ' Chron.com
smallbusiness.chron.com/transfer-nook-books-different-nook-27403.html Search for: How to transfer books from old nook to New Nook?
How do transfer my library on my old Nook to my new Nook Google Search
Feb 07, 2017 | Tablets & eReaders
I have charged my Nook HD but it won't turn on. What can the problem be?
Do you have the charging graphic as in this image Nina?
How to Reset Nook HD
If yes, send it back. If not, your charger is faulty. Try charging with a computer USB.
Jan 21, 2016 | NOOK HD 7 Tablet
Will not take a charge a
Barnes & Noble Nook HD
Jan 01, 2016 | Barnes & Noble Nook HD
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
Disable demo mode on nook hd+
Go to settings, then device information. While pressing the volume up button, tap above the volume bar and a popup menu will appear. Uncheck "Enable demo mode", then power down your Nook. When you restart it, the Nook should be in regular mode.
Nov 01, 2014 | Nook HD+
What to do when my nook freezes
try to power down the device and then back up again, then try what you were trying to do.
May 30, 2014 | Barnes & Noble Nook Color
Why my nook tablet will not turn on ?
If the screen is off and won't turn on, make sure the battery has a charge. Plug in your device for 30 minutes before trying anything else. If it is on or if the battery has a charge you may need to "hard reset" the Nook. Although this is very uncommon, it may happen. Below are a few solutions that may help.
  • Hold down the power button for 10-15 seconds. The Nook should power off and you can turn it back on again. Everything should work normally.
  • If that does not work you will need to hold down the power button and the "N" button for 10 or more seconds. Again, this should force your device to power off and you can start it up normally.
  • Take out the N2A Card and try the same steps again. Your Nook should boot up into Nook mode. You'll have to restart it again with the N2A Card in to boot up in Android mode.
One of the tasks above will usually correct this issue unless you have a hardware problem with the Nook. Our cards cannot cause hardware problems unless they are forcefully inserted wrong. If you determine you do have a hardware problem you will need to take the Nook back to the retailer if it is still under warranty. The Nook usually comes with a one-year (non-accidental) warranty through Barnes & Noble. Some retailers, like Best Buy, exchange them in the store under warranty.
Don't forget to hold onto your N2A Card until they return your Nook!
If you still have any kind of issue thenhttp://www.tablethelpline.com/nook-support/ you can take Nook Help from experts by calling nook customer service number.
May 16, 2014 | Barnes & Noble nook color eBook Reader
My sync continiosly spins, however book will not update or appear on my screen. I have to download all books to my PC and then on to the Nook
I've had the problem where my nookcolor would not sync with the B&N nook for pc. Updated the software to 1.01 and it worked until I hooked the cable up to my pc, then it stopped updating again even though I had ejected (safely remove hardware). I tried reseting the nook "hold the power button a few seconds and then press and hold the volume up button, release both when screen flashes. I have to repeat this each time I hook the nook to the pc and eject.
Joe
Jan 01, 2011 | Barnes & Noble nook color eBook Reader
Barnes & Noble NOOK Tablet HD 8GB BNTV400 Logo
242 people viewed this question
Top Barnes & Noble Tablets & eReaders Experts
Miguel Luiz Martins
Brett Duxbury
Brett Duxbury
ray gallant
Are you a Barnes & Noble Tablet and eReader Expert? Answer questions, earn points and help others
