I have a 42inch bush tv and it's been working perfectly fine until this week. The tv now displays a blue flashing light all the time and won't let me turn it off or on. What shall I do?
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Try a hard reset, before doing any repair to this set. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better.
Posted on Nov 17, 2014
  • Mara Nov 17, 2014
    Okay, I'll try it! Thank you!
  • The Knight
    The Knight Nov 17, 2014
    Ok. Wish to get any more details; contact me by Fixya comment; please.
  • 105 Answers
SOURCE: my tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Posted on Apr 29, 2009
dsacco86
  • 1077 Answers
SOURCE: blue light flashing 4 times
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. I don't have the actual Service Manual for your TV to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
Raditronic
  • 196 Answers
SOURCE: My Panasonic tv displays only a thin blue horizontal line
This is vertical problem. The tv have a cold solder in vertical ic or ic is bad.
Posted on Apr 22, 2010
SOURCE: Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Posted on May 05, 2010
SOURCE: Problem with Hitachi P50H401 Plasma TV - Will not
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
Posted on Jul 03, 2010
Bush tv 3 weeks old, tried turn it on but just a black screen,standby light turns blue as if it's on also if I press any buttons on it the blue light flashes like working but just a black screen
Here goes:
#Press and hold the on/ off button...
#Whilst holding unplug the plug from the wall...
#Continue holding for 30 seconds...
#Plug in the plug whilst continuing to hold the on/ off button...
#Continue to hold for a further 30 seconds...
And the screen should come back on!
Jul 23, 2016 | Bush Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Remote control slow to respond to Bush tv (LT42M1CFA)
Even though your TV s remote control emits infrared light, it might have not sufficiant frequency as it supposed to be. The fault with its resonator crystal inside the circuit board need replacement. It will look like this. Replace it with exact frequency marked on it.8_16_2012_4_53_50_pm.jpg
Aug 15, 2012 | Big Button TV Universal Remote
Bush IDLCD26TV16HD blue flashing light?
It is on protection mode due to some defects on the board. Switch off the TV manually, remove the plug and cool it off for 48 hours and retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Bush Industries IDLCD26TV16HD LCD TV
42inch bush tv has just turned its self of no buttons were pressed and the lights still on
the sound is an indication of a short in the set--have a shop take a look as this likely is not a do it yourself repair.
Apr 16, 2012 | Televison & Video
My Mitsubishi wd-65731 only displays a blue screen. It has been working fine for 5 years now.
Check video source first. Check other inputs. . Then hold down first and 3rd button from the right on tv for 5 seconds until green led flashes. count the flashes. It will flash several times pause then flash several more times. This is a code 2 digits. Let me know what code is.
Aug 30, 2011 | Mitsubishi WD-65731 65" HDTV
Cintiq 12WX screen not working :(
may be the power chord is damged go to a nearby shop and tell tham to give you a new power chord of monitor and then try it should work fine
thank for visiting fixya
have a nice day
Feb 19, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
My sirena does not work
anytime the water runs out and you need to refill the tank, you need to bleed the line so to speak. Take an empty cup and put it under the wand and open the knob of the steam wand until the blue light stops flashing
Feb 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
