Question about Exercise & Fitness
How do I replace battery for lifefitness 95Ri
    Sergeant:
  • 269 Answers
Here is the manual. It doesn't explain in detail but it gives you a complete parts diagram which you may be able to follow. http://pdfstream.manualsonline.com/4/44698565-5840-46af-8320-6cdde4a3d916.pdf
Posted on Nov 17, 2014
I have a Life Fitness 95Ri recliner cycle which has suddenly stopped working. The display doesn't power on when you start cycling. No lights at all.
If you post your query in home fitness equipment, you may get more response. This forum is for cameras
Jun 03, 2017 | Cameras
Tip
95Xi Crosstrainer Shroud Replacement
Video Presentation of Replacing the Main Shroud on a LifeFitness 95Xi Crosstrainer
  • The video shows the steps involved in replacement of the main shroud on a LifeFitness 95Xi
  • Tools:
    • Phillips Screwdriver
  • Remove the (4) screws securing the main shroud to the drive frame assembly
    • There are two screws on each side
  • Lift straight up on the shroud to remove it
  • Install the main shroud in reverse order
    • Making sure the main shroud fits into the grooves of the lower shroud panels
Repair Video for LifeFitness 95Xi Crosstrainer Shroud Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Tip
95Xi Crosstrainer Pedal Replacement
Video about How to Replace the Pedal on a 95Xi Crosstrainer by LifeFitness
  • This video is about how to replace the pedal on a 95Xi LifeFitness crosstrainer
  • Tools necessary:
    • T40 Torx Driver
  • Remove the (4) torx bolts securing the pedal to the pedal lever assembly
  • Install the new pedal in reverse order
  • This completes the replacement of a pedal on the LifeFitness 95Xi
Life Fitness Crosstrainer 95Xi Video Pedal Replacement
on Apr 28, 2014 | Exercise & Fitness
Where is the battery on the life fitness 95xi
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Dec 29, 2013 | Life Fitness 95xi Elliptical Crosstrainer
Life fitness elliptical X3
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
The following link will take you to the information we have for the X3 by LifeFitness. Please have your serial number available.
Repair Parts for X3 Crosstrainer by LifeFitness SPORTSMITH net
Oct 23, 2013 | Exercise & Fitness
We have information for LifeFitness available on our Website. Please have your model and serial number available. The following link will take you to our LifeFitness page. Life Fitness Crosstrainer Repair Parts Belts Batteries SPORTSMITH net
Aug 06, 2013 | Exercise & Fitness
95Ri display board will not work
1) adjust the REED switch, see the diagram clean it , and tight the wires connector very well.
2) tight the ribbon cables from keypads, tight the wires connector from display board vs lower board.
God bless you
Jul 20, 2012 | Exercise & Fitness
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
Lifefitness 9500hr recumbant exercise bike dead
This unit takes a special 6 volt battery. The battery is in one of two places. First place to look is under the unit. If you lay the bike over on its side there is an opening in the covers. If the battery is not there then you will need to take one of the side covers off. When you get the side off you cannot miss it. The battery is black with three cylinders. You can get the battery from sportsmith.net.
Mar 15, 2010 | Exercise & Fitness
Cant get the lifefitness treadmill T7-0 to work
you may need open up the head board and check the switch.
Mar 29, 2009 | Life Fitness LifeFitness 97Te Treadmill
Exercise & Fitness Logo
269 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
