How do I change show size in my last order?
I need to change size to 11
Changed the battery, but clock will not work. Has been without a new battery for months. Is there a reset button in the back battery compartment?
I have the same problem with a 20 inch clock that I found at Goodwill. The solution is to purchase a new quartz clock movement...they can be found on eBay for around $11 including shipping. You will need to open the case (probably held by screws on the back), pull the hands off the post and slip the unit out of the back of the clock. Measure the post and order the size needed. I ordered from clockman80, and all the info you need to order is on their auction page. You can also contact them if you need help. You have to decide if you like the clock case enough to go to a little trouble, but I liked this clock and it was like paying $18 for a $40 clock. It should now last for another 10 years :)
Sep 22, 2013 | Sterling & Noble 20 Wrought Iron Wall...
About the last 2 inches of the copy does not print????
Is the paper in the tray the correct size for what is supposed to be in it. For example does tray 1 have 8 1/2 x 11 paper in it and does the indicator on the control panel show that size ? Good luck.
Jul 15, 2011 | Sharp AR-M205 Copier
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
How to print 11 X 17 documents using a Kyocere CS 2550 printer
Use this method:
[File]
[Print]
Select the printer from the list and click on [Properties]
Change the "Original siae" to "11x17"
Change the Output size from "Same..." to "8.5x11" or "8.5x14"
[OK]
[OK]
Sep 29, 2009 | Kyocera CS-2550 Black and White Copier
I'm trying to print some photos on 4 x 6 paper. i selected notecard paper size, but the printer keeps printing the 4 x 6 photo on 8 1/2 x 11 paper.
Are you telling the printer to use the smaller paper?
If it has 2 sizes it will keep using the last size used unless you tell it to change.
Sep 27, 2009 | HP Photosmart 3210 Printer
Printed 12 inches
check the page setup for header and footer margin sizes and top or bottom margin sizes .
May 13, 2017 | Tally LA650 Matrix Printer
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
29 people viewed this question
k24674
jasbo
jasbo
