Question about Canon PIXMA Office Equipment & Supplies
Cannon Pixma 922 support code C000, does not print
Have disconnected all lines in and still error message says to turn off and restart, but still blinking error light
    Sergeant:
  • 269 Answers
Error Code C000 refers to a paper jam, even caused by a small piece of paper. Sometimes you can reset the error by opening and closing any access doors.
Posted on Nov 17, 2014
Testimonial: "changed out new cartridges, checked all paper ports, no paper pieces, opened/ closed all access doors, still same. Last resort; purchase another machine"
4 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
pineworks
  • 4041 Answers
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
reyjoshua07
  • 1157 Answers
SOURCE: Printer: Cannon Pixma 6120 Will
Hi drwaspo,
The "error C000" displays when the ink cartridge is not seated properly. The easiest way to resolve this is to remove an incorrectly inserted ink tank. The top portion of the ink tank should be in place and the top portion must go beneath the ink color name sticker. Here are some steps that you may use to correct this problem.
1. Unplug the unit from the power outlet.
2. Open the top cover and move the print head holder to the center. Print head holder may be at the left side of the printer. Lifting the print head holder before sliding it to the center may help you do the operation.
3. Remove two left most ink tanks following the procedures below.
--> First, push down the upper part of the ink tank until it slides under the cover so that the ink tank fits into place.
--> Then, push the latch lever in the direction of the arrow and pull out the ink tank.
4. Pull out the rest of ink tanks one by one:
--> While holding the upper part of the ink tank, remove the ink tank by gently twisting it.
5. Turn ON the printer again.
6. When the Print Head Holder moves to the ink tank replacement position, insert the ink tanks properly.
--> Do not hold the Print Head Holder to stop or move it forcibly. Do not touch the Print Head Holder until it stops completely.
Hope it helps.
Thank you for using FixYa.
Posted on May 18, 2011
Canon MX922 printer displaying code C000
Try switching printer off then unplugging the power for 15 or so minutes. If that doesn't work and same error pops up when you turn printer back on, contact Canon.
good luck
Feb 28, 2015 | Canon PIXMA MX922 Wireless InkJet MFC /...
Error code cooo
Go To Below official Canon Printer Page For Your problem,
http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 06, 2014 | Canon PIXMA MG5320 All-in-One Printer
Canon mx860 - had an error code C000 and now a day later 306A
Error code C000. Cancel printing, and turn off the machine. Then clear the paper jam or foreign object that is preventing the Print Head Holder from moving.
For more information about the error code C000, can be read here Canon Support and Downloads
You read, the bottom of the page
Sep 23, 2011 | Canon PIXMA MX860 All-In-One InkJet...
I have a error message that says to turn off and if it doesn't clear look at manual. well I can't see to find an answer. error code C000 printer error, help
hi this error code c000 is a possible indication of your ink cartridge/either needs cleaning/or check that they are properly seated/ie take them out and re-seat them back into there holders/the other possibility is you may have some print paper stuck in the roller/this needs to be checked.hope this helps.
Aug 20, 2010 | Canon PIXMA MX850 Multifunction Printer
I get an error message c000 when i turn on my
Feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective. The purge unit pump or hose is clogged...recommend having serviced by tech.
Nov 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error Message C000
Purge cam sensor error [5C00] An error occurred in the purge unit. - Purge unit
- Logic board prbelom
Sep 09, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
212 people viewed this question
old marine
old marine
