Question about Refrigerators
GE side by side fridge model GSR23VSTA-SS freezer temp -25F fridge temp 40F freezer set at -3F fridge set at 40F
Would it be a thermister
  • Refrigerators Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Posted on Apr 17, 2015
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
Posted on Apr 22, 2008
  • 93 Answers
SOURCE: GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Posted on Jul 17, 2008
SOURCE: GE Side by Side Fridge Problem
could be defrost problem. check frost pattern on evaporator.
Posted on Jul 22, 2008
SOURCE: GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Posted on Jul 30, 2008
Model #FGHC2331PF frigidaire. Controls were set for 35F fridge and 0F freezer, but when the fridge stopped the temps went up. They are now at 40F fridge and 5F freezer. Why?
Because nothing is perfect. As soon as the compressor stops running, the refrigerator will start to get warmer as the ambient temperatures will affect it. Then after a few degrees of temp rise, if thermostat is working properly, unit will kick on again to lower temps to preset level. And the cycle continues.
Apr 02, 2016 | Refrigerators
HOW DO I FIX
I see nothing about checking freon level .
Nov 24, 2015 | Refrigerators
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
We bought a used whirlpool refrigerator model ed25rf. how long should it take to get completely cool to the right tempature
Overnight should be adequate. In the fresh food section temp should be around 40F in the freezer it should be 32 to 25F or lower.
Aug 14, 2014 | Refrigerators
Kitchenaid side by side fridge is freezing food
you have a bad damper assy.when it gets cold enough in the fridge section the damper door closes so the cold air can't blow in from the freezer side,the door isn't closing allowing the cold air to keep coming into the fridge side 2220377 part number and this is electronic damper.if you order it from repair clinic you have 365 days to return it if it's damaged or it isn't your problem they will take it back,i'm 99 percent positive that this is your problem,when i would call the customer and get model number and ask a few questions i would take this with me when i go to the house from the discription you're giving.
Dec 05, 2013 | KitchenAid Superba Architect KSCS25INSS...
Kenmore side by side Model #106.55532400 Orignally the frig. side would not cooled down below 40F even when the digital control was lower to 33F. The unit was unloaded and turned off for 24 hours, doors...
Yes the thermister is the electronic thermostat...on models such as yours that has a computer control a thermister is used..on models that the knob is turned to set the temp. and has no digital dispay a thermostat is used
The part number for the thermister is 2188819
It fits by air damper in the fresh food compartment in the upper left corner of the fresh food compartment
GENE
Sep 09, 2011 | Kenmore Side by Side Refrigerator
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
CallMe-
Best of luck.
Jul 28, 2008 | Refrigerators
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
