Question about Honeywell T6360b1028 Room Thermostat
Change a four wire room thermostat to a two wire room stat
I need to change a four wire room stat to an two wire as I cannot find a replacement four wire room stat Regards bill
  • Honeywell Master
  • 10,263 Answers
Woah...will never work. The thermostat gets power from the red wire and the other wires operate the indoor fan relay and the compressor. You can get a universal t/stat at any home improvement store or online.
Posted on Nov 17, 2014
    Sergeant:
  • 269 Answers
I have hot water but can't get heating to come on
you don't say what type of boiler you have, but as a guide...
Three port valve may not be operating.
Heating Pump may not be operating.
Room thermostat incorrectly set or not working.
Start with the room stat as it controls the valve and the pump..
More information about your system is needed to help you further..
Apr 17, 2017 | Water Water Heaters
How to adjust thermostat
How to Adjust Honeywell T6360b1028 Thermostat? ' DIYnot Forums
www.diynot.com > Forums > How to... > Plumbing and Central Heating
Unless the thermostat is faulty, the point where your 'stat clicks is your actual roomtemperature. If your 'stat doesn't 'call for heat' when set to 18 and your room ...
Nov 01, 2015 | Honeywell T6360b1028 Room Thermostat
Rheem ac/heater only works with thermostat in on position
Another infamous question where the inquiry is not well stated.
Are we talking HVAC as this is posted in Water Heaters?
And,gosh, doesn't it make sense that when the T-Stat is on.......amazingly the unit works?
As opposed to when it's off and the unit is still energized?
Oct 20, 2014 | Water Heaters
Heater does not come on unless thermostat is in on position. replaced thermostat and still not working on auto position any ideas?
If this is HVAC you've wired the T-stat wrong.....probably even have the wrong # of conductors or you reversed it.
There is a wiring guide on the Blister pack the Stat came in...read and abide by the diagram
Glowworm 24cxi
Check if you have the link still in place, it seems its wired incorrectly through the bus circuit remove link and re wire
Apr 06, 2014 | Water Heaters
Worcester DT 20 RF Room Stat, when batteries were replaced in correct positions the unit still did not show any signs of life
It is recommended that you use all new batteries when replacing them in the Worcester DT 20 RF Room thermostat. Rest the power on the heater with the thermostat near by, this will reestablish wireless communications between the two. You will need to reprogram the heaters timer as well.
Dec 11, 2010 | Bosch Water Heaters
New sime e comfort 25HE boiler problems
It not wired in right that why its coming on when it is off The boiler is over riding the programmer when it is off .
The boiler should call for heat if programme is on it sounds like boiler is wired into the 24hr mode or over ride mode that why it is coming on . google wiring for y plan heating system. this will help you fault find on this . changing vales and thermostats will not help you . Hope this helps .
Mar 05, 2017 | Water Heaters
Central heating on all the time!
The zone valve needs replacing.
Sep 24, 2009 | Water Heaters
Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Oct 26, 2008 | Water Heaters
Honeywell T6360b1028 Room Thermostat Logo
133 people viewed this question
Top Honeywell Water Heaters Experts
Lickzee
gbob59
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
