Question about Health & Beauty
I asked a question a week or so ago, no response yet
Set has nubs and sleeping on the sheets feel like I am in a batch of sand one morning there were specks of blood from my legs from the grit. I am of the age that skin is thin
5 Suggested Answers
  • 1218 Answers
SOURCE: Orca 3500x paper shredder, not
Open it up and see if any of the plastic drive gears are damaged...for parts assistance give Royal a call at 1-800-524-0799.
Posted on Sep 29, 2010
  • 4736 Answers
SOURCE: devise that is used to
Some folks have this problem. But, it usually can be solved by pinching the flesh in the area you're going to use and hold it while you use the lancet. Also, you may have to try using a different type of lancet, that will pierce a little deeper.
Hope this helps you.
Posted on May 17, 2011
SOURCE: please tell me best moisture for slightly oil skin
Artistry Time Defiance Daytime Protection Lotion - SPF - Combination-to-Oily Skin is a great daytime moisturizer if you have have slightly oily skin.
The ultimate anti-aging daytime lotion to defy age beyond procedures. This intense daytime moisturizer with SPF 15 stops aging where it starts. Daytime Protection Lotion visibly reduces the appearance of wrinkles by more than 50% in 12 weeks.
http://www.amway.com/sorenson/Shop/Product/Product.aspx/ARTISTRY-TIME-DEFIANCE-Daytime-Protection-Lotion-SPF-15-Combination-to-Oily-Skin?itemno=101822
Posted on Mar 14, 2012
SOURCE: what cause decrease blood flow in my legs?
Use arnica gel
Posted on Jan 29, 2017
I have at the moment a very high heart rate and I am very tired, just want to sleep all the time ? Can you please help me ?
fixya site is not a medical forum
with this condition you should have been talking with a doctor or a heart specialist 2 weeks ago
Jun 24, 2017 | Cars & Trucks
How to change sanding pad
Here is a link to the manual to your Royobi p400. You can download it. Tried to copy & paste the illustrations but they did not show up. Go to page 14 of the manual. Looks pretty easy, just peel down from top. Good luck. & happy Sanding.
CHANGING SANDING SHEETS AND PADS
HOOK-AND-LOOP
See Figure 8.
PAD
The sander is packed with sanding sheets and scrubbing
pads designed for a variety of uses. To change sheets and
SANDING
pads, simply pull the used sheet off the base and attach the
SHEET
desired sheet by pressing the sheet or pad onto the base
of the sander.
ROTATING THE SANDING SHEETS
See Figure 9.
The majority of wear in a precision sanding application occurs
at the tip of the sanding sheet. The unique Tri-Flex design of
the sanding sheets allows you to detach and rotate the top
two thirds of each and extend the life of the sheet.
To rotate the top of the sheet, simply remove the top two
thirds along the perforation. Rotate the sheet so that a clean
corner is located at the tip of the base. Press the sheet firmly
onto the pad.
NOTE: Scrubbing and polishing pads are not perforated
and cannot be rotated.
Apr 24, 2014 | Ryobi P400 18 Volt Corner Cat S
Can you catch up on sleep on the weekend by taking a sleeping tablet and just sleeping a lot more than you do during the week?
No - if you sleep a lot more on the weekend, it's a sign that you have a sleep debt and your body is trying to get more sleep than usual. But it doesn't help your body to feel less tired. You need to spread out your sleeping over the whole week and not try and cram it all into one night.
Feb 20, 2013 | Health & Beauty
I sleep with a fitter sheet but for some reason my air mattress is always wet in the morning. Why?
It's because your air mattress, unlike a regular mattress, is made with completely, airtight, non-breathable material. So instead of absorbing moisture, you sweat remains on the top of the mattress.
Jul 09, 2012 | Camping, Backpacking & Hiking
2 weeks ago I bought my mixer. It sounded very smooth. I made 1 batch of 4 cup bread, 1 batch of 8 cup bread, and whipped cream twice. Now it is making a rough, whining, grinding noise. It isn't the...
That could be gears or the motor or the connector to the mixer head etc. Since this is two weeks old I wouldn't even worry about what just take it back and get a replacement. Even the new kitchenaids are very good and very realiable after years of use and abuse. Abuse is something like Dad I tried making sand from some rocks. Still worked after that btw.
You just got a bad unit which from my experience has been pretty rare. It will be under warranty so just get it replaced and enjoy the new one for years to come instead of worrying about this one.
Feb 27, 2011 | KitchenAid KV25G0X Stand Mixer
Stand by time is flashing tv will not start
no the tv has no battery for memory.the memory is supplied by the 5 volt standby.the tv must be plugged in to maintain the 5 volts to keep its memory.
Jul 18, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Engine light is on.
Your vehicle’s computer system has self-testing capability. When the computer senses that there is a problem with some of the components it stores the correspondent trouble code(s) in its memory and lights up the Check Engine or Service Engine Soon lights to tell you that there is a problem and you should have the car diagnosed and repaired. Not fluid related, but could be a small problem that's easy to fix now. Even a loose gas cap can turn the light on. Have a code scan, that's the starting point.
Dec 16, 2008 | 2002 Isuzu Axiom
Zoom toggle switch problem
you need:
1: a small and strong phillips screwdriver.
2. a small piece of medium strength plastic.
(I used a wall anchor like you would use for drywall)
3. superglue
4: about 15 minutes
5. some gumption
6. a bit of sandpaper, in case you screw up step 4.
step 0: You are about to void any warranty. Accept this, and move on. Take out the battery and the memory card.
step 1: remove case of camera. be careful not to strip or loose your your screws.
step 2: gently give the thing a shake. likely a tiny piece of black plastic will fall out. this is the piece that originally attached to the back of the zoom rocker button. if it doesn't come out, don't worry.
step 3: take a look at the back side of the still functioning side of the rocker button. you will see a tiny nub on the back. this nub compresses the pressure switch that is built into the circuit card of the camera, activating the zoom.
step 4: cut a piece of plastic that is about the right thickness to replace the missing nub on the non-functioning side of the button. you will be better off cutting it a bit too thick than too thin.
step 5a: VERY carefully superglue the bit of plastic to the back of the button. you don't need that much glue.
Setp 5b: let me repeat, YOU DON"T NEED THAT MUCH GLUE!
Step 6: Let the glue dry. completely. I mean it.
step 7: replace the case, and about half the screws. put the battery and card back in.
step 8. power on, and test the zoom. It should work now. if it feels like the button is too loose, or still isn't making contact, you cut the plastic too small; Sand or snip it off and start again.
Step 9. If it feels like the button is too hard to push, the plastic bit is too large. You can cut it down a bit, sand it, or just put the rest of the screws in and be thankfull that you repaired your camera for about 2 cents worth of material, and 15 minutes of work.
Step 10: make sure you don't have any extra parts. make sure you didn't screw up another button while you were mucking about.
I've done this. It works. Repaired mine about 9 months ago, and no issues since...well, I put the button in upside down, but it works exactly the same, so that doesn't count as an issue.
If FUBAR your camera, I'm not responsible.
Long live Nikon,
-aboniks
Sep 19, 2005 | Nikon Coolpix 4500 Digital Camera
Health & Beauty Logo
43 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
