Question about RCA RP-7994 Cassette/CD Boombox
<!-- from fixya rte -->What type of power cord do I need - RCA RP-7994 Cassette/CD Boombox
I lost the power cord to my "vintage fiber optic light" and would really like to use it. I don't know the voltage, so I can't even try to use another cord. Any ideas I what I can do?
If it is the type that has a cord, a power transformer and then the unit, look on the area where the power cord plugs into the unit. It ought to have the voltage, milliamps needed and the polarity.
If you have only lost the power cord, it just need to same type of plug.
Dec 11, 2016 | Office Equipment & Supplies
I need a power cord for it.
hello nancy, what is the type of your power cord? i put a picture so you can see what type of cord.. you can buy a power cord at your local electronics store or appliances store..
Aug 04, 2015 | Kitchen Appliances - Others
I need replacement power cord
Well, if the power cord isn't hard wired to the TV, then the two most likely options are either a figure 8 cord or an IEC cord.
Here's a figure 8 at monoprice
3ft 18AWG Figure 8 Shape AC Power Cord Cable Polarized 7 1 15P Black...
Here's the IEC cord at monoprice 10ft 16AWG Power Cord Cable 3 Conductor PC Power Connector Socket C13 5...
Sep 05, 2014 | Coby LEDTV2326 23 TV
Lost power cord
The power cord for most of these televisions are a very common type and easy to find. They are used in many types of electronic equipment.
Jan 17, 2014 | AOC 23 Envision LE23H062 1080p Widescreen...
How do I know which type of power cord I need for my Sanyo Vizio CLT2054-04 tv? I understand there are 2 types of 4-pin cords depending on the polarity? The original cord is lost. Can I tell from...
Go to a Samsung dealer ir servicer and take the model number with you. The difference in the power cords is not polarity. It's whether or not it is for 115VAC or 220vac More than likely you need the one for the US--115vac.
Oct 29, 2013 | Televison & Video
I need to find a replacement power cord for this tv, any suggestions? I can't find it
you don't say what has happened to existing cord or what is wrong with cord. Have you tried to get a replacement cord at a tv repair shop?
Nov 24, 2012 | Televison & Video
I need a power cord for my tv
ANY 3 prong cord will work. These include computer power cords, 12v inverter power cords (brick type), etc.
Thank you!
May 02, 2011 | Protron PLTV-32 Television
I need a new power cord. Can I buy one?
There are many different power cords for shavers. You will need your make and model number to select the correct type. You will find most types of shaver cords at shaveroutlet.com
Nov 30, 2010 | Health & Beauty
What voltage should be read on each pin of the power adapter?
hello ,, this information is based on ScanJet 5400C - (C8517V) -- if yours is other p/n, let me know
North American use , C8517-84200, Low power AC power module (Wall Mount Type) - 100-120VAC, 60Hz - Detachable power cord not needed (USA, Canada) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
European use , C8517-84201, Low power AC power module (Wall Mount Type) - 200-240VAC - Detachable power cord not needed (Europe) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
Worldwide use , C8517-84201, Low power AC power module (Brick Type) - 100-240V input - Requires a 3-wire detachable power cord - For worldwide operation - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
i hope thsi helps -- if it does, please rate my service
Nov 13, 2010 | HP Scanjet 5400c Flatbed Scanner
RCA RP-7994 Cassette/CD Boombox Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
