Eletrolux w3130n fejlkode E10
Hvad er fejl kode E10
5 Suggested Answers
pcs365
  • 128 Answers
SOURCE: Ved opstart af window defender
From your description, I understand the issue to be: you received VSS error 0x8007042d.
I. First please re-registry the following DLLs to see if it helps:
1. Stop the Volume Shadow Copy service: Open a command prompt and change
directories to \WINDOWS\system32 (this is important when you begin
registering the DLLs):
net stop vss
2. Then register the following DLLs and services (be sure you're still in
the WINDOWS\system32 directory at your command prompt):
regsvr32 ole32.dll
regsvr32 vss_ps.dll
Vssvc /Register
regsvr32 /i swprv.dll
regsvr32 /i eventcls.dll
regsvr32 es.dll
regsvr32 stdprov.dll
regsvr32 vssui.dll
regsvr32 msxml.dll
regsvr32 msxml3.dll
regsvr32 msxml4.dll
Start the Volume Shadow Copy service by running "net start vss", do a test
backup and see how it goes.
II. If the issue persists, Let's perform these troubleshooting steps:
1. Make sure you can use OSQL to connect to every running instance of
SQL/MSDE on the box, if you can not disable all of the instances.
You can find all of the instances installed on your server, by looking at
this registry value: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL
Server\InstalledInstances
The syntax would be "OSQL -E -S <servername>\<instancename>
For example OSQL -E -S server\SharePoint
If you can't connect to the database, then it will cause this type of
failure.
Also make sure that each of the SQL/MSDE instances is either running under
the Local System account or a Domain Admin account.
2. The issue may occur if there is corrupted data on the drive to be backed
up. Please run CHKDSK on each drive with the /f switch to fix the errors on
the disk (if there are any).
3. Per my experience, this issue can be due to VSS thinks the system is
still in setup process. Please perform the steps below to check the status.
WARNING: Using Registry Editor incorrectly can cause serious problems that
may require you to reinstall Windows. Microsoft cannot guarantee that
problems resulting from the incorrect use of Registry Editor can be solved.
Use Registry Editor at your own risk.
Open the registry and locate the registry key:
HKEY_LOCAL_MACHINE\SYSTEM\Setup
Ensure both registry values are set to 0:
- SystemSetupInProgress
- UpgradeInProgress
4. If the issue still happens, reinstall COM+ by following these steps:
A. Backup and then delete HKLM\Software\Microsoft\COM3
B. Boot to Recovery console and rename clbcatq.dll to ~clbcatq.dll. Be sure
to use the tilde.
C. Boot to normal mode and in Control Panel, open the Add or Remove
Programs tool, and then open the Add/Remove Windows Components tool. Do not
make any changes, just click "Next". This reinstalls COM+.
NOTE: You must have your Windows Server 2003 SP1 files available during
this step.
Hope above information helps! I am happy to be of assistance to you and
look forward to your reply!
Posted on Jun 02, 2010
TDISLine
  • 1874 Answers
SOURCE: audi A4 1996 radio skriver
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for Audi radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Posted on Oct 28, 2010
puertobori
  • 7733 Answers
SOURCE: Hej Mit problem er at jeg
ggo to NETGEAR Router
  • 13433 Answers
SOURCE: Testresultater for DirectSound: Fejl ved
I'd suggest that you reinstall direct x and the sound cards drivers, if you could post the brand and model of the mainboard and the version of windows that your running, also we can do a remote support session and I can try to fix it up for you if reinstalling DirectX and The drivers doesn't solve it.
Posted on Feb 05, 2011
Ducati multistrada 1000 ds EFI kode 34.0 hvordan fiksa det
Hei , Anonymous for denne situasjonen jeg vil kalle min lokale forhandler eller hederlig butikk service / deleavdeling og sp?rre om eventuelle quick fix , svar , eller deler foresp?rsel . Hvis det er n?dvendig , transportere sykkelen til forhandleren eller shoppe og ha en profesjonell tekniker ta det for en pr?vetur , hvis det er i l?pende tilstand , og gi deg et skriftlig anslag for reparasjoner og svare p? eventuelle konkrete sp?rsm?l du m?tte ha om problemet. For mer informasjon om problemet og verdifulle gratis nedlastinger som du trenger kan du bes?ke nettstedene nedenfor. Lykke til og ha en fin dag. Need info error code 34 0 Signal Panel Sensor
38 0 Error code
Ducati Multistrada 1000DS 2003 2006 Repair Service Manual Download Manuals...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
May 08, 2012 | 2006 Ducati Multistrada 620
Scannern fungerar inte
ehh hva er det som er feil forklar problem og feilmelding ( kode )
Jan 30, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Audi A4 1996 radio skriver safe. hvad g&#195;&#184;r jeg. har ingen kode?
Oct 27, 2010 | 1996 Audi A4
Returblekk n?r full
Hej Lars,
Jeg kan ikke finde noget der ligner din fejl beskrevet. Men, - er det en "gammel" tank du forsjøker at fylde blæk på?  -> så skal du kanske kjøbe en ny original tank.
Ellers kan du jo også telefonere Canon Norge HER: og spørge dem. Der findes ej spørgsmål lignende dit på Canons hjemmeside.
venlig hilsen /Teis Håber du finder svar! 6a71920.png
Ked af at jeg ikke kunne hjælpe dig
Jan 11, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Min router fungerer fin via kabel. men efter en reeset af routeren kan jeg ikke l?ngere logge p? tr?dl?st. Hvordan finder man en ny n?gle???
Hej Trille,
- generere nye koder?
Det bliver uden tvivl noget grusomt "giberish" = uforståligt :-)
Du kan selv lave din egen kode, og VæLG key 1, for der er desværre trådløse kort der KUN har key 1.
Nu da du så har fået sat en kode på routeren, skal du "bare" sætte den samme kode på dit trådløse netkort.
Model - og jeg kan hjælpe
Hvis ikke, - så ville det da ikke gøre mig det mindste hvis du "vote" "FixYa" :-)
arbejder på at blive Guru her på siden :-)
Dec 03, 2008 | Linksys Wireless-G Broadband Router
HP2575 Problem with scanning docs or pictures.
When you loaded the software for the printer did you do the full installation? I have looked on various forums for this issue and it appears that it will work in HP Solutions, is this the installation package that it may be looking for?
Nov 27, 2008 | HP Photosmart 2575 All-In-One InkJet...
Washing Machines Logo
Top Washing Machines Experts
