Casablanca remote W42 works only 3 minutes! I changed the settings many times, reset (hi-med-low), turned off the breaker, cleaned the inside rubber of remote with alcohol! I'm hearing a "click" from
Casablanca remote W42 works only 3 minutes! I changed the settings many times, reset (hi-med-low), turned off the breaker, cleaned the inside rubber of remote with alcohol! I'm hearing a "click" from the fan and all shuts down!!! Help
  • Debora I
    Debora I Nov 17, 2014
    Wong topic -sorry
SOURCE: Battery Indicator Flashing and then Camera Shut down
I have the same problem on the same cammera. I sent it to canon and they say they will fix it for free. I have the same problem on a canon a530 and sent it to them also. My wife had droped that one and put a dent in the metal around the lense worked fine but they said they must fix it along with the battery problem at a cost of $108. Give them a call 1800 652 2666.
Posted on Feb 26, 2007
SOURCE: Nokkon D50 showing err on ctrl panel
Try this. I own two D50's.
Move the settings to manual on the dial and the lens.
Take out the lens
Take two pictures.
Replace the lens.
Move to automatic position on the dial.
Hopefully the error has gone away.
Guy
Posted on Dec 27, 2008
SOURCE: Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Posted on Mar 02, 2009
SOURCE: My Hampton Bay Miramar 60 in ceiling fan, works
Mine just died!!! Can't get the control in side, and they don't have them in stock at home depot anymore here. OK. All hampton bay fan have a lifetime warrenty... they will take mine back, paid $229, but will only get $106 because they had a close out!!!
Good Luck!! I know I loved my fan, going to miss it beauty
Posted on May 20, 2009
MN_Jack76
  • 45 Answers
SOURCE: my casablanca fan versa touch 2 does not respond to remote control -
I believe there is a dipswitch, and a non- dipswitch version. To sinc the remote to receiver, shut power off to the fan receiver by either a switch or breaker for about 10 minutes, turn power back on and press Hi, Medium, Low on the remote in that order. this should get them "talking" again. If this does not work, contact toll-free Jason at Fan Man Lighting 1-866-600-3267, he has 30 years experience with casablanca
Posted on Oct 17, 2009
My 12000btu spliter air condition start and stop in 5 seconds
24
EN
TROUBLESHOOTING
CAUTION
If any of the following conditions occur, stop the air conditioner immediately, turn off the main power switch and contact the
dealer.
• The indicators flash at short intervals (5 Hz). Reset the circuit breaker 2 to 3 minutes after the power main switch is turned
off.
Despite the resetting operation, the indicators still continue turning on and off.
• The main power fuse often blows, or the circuit breaker is often activated.
• Foreign matter or water has fallen inside the air conditioner.
• Any other unusual conditions are observed.
Before asking for servicing or repairs, check the following points.
Recheck
Inoperative
• The power main switch is turned off.
• The circuit breaker is activated to cut off the power supply.
• The main power fuse has blown.
• The electric current has stopped.
• The batteries in the remote controller used up.
• The ON timer is set.
• As a protective mechanism for the air conditioner, it does not operate for 3 minutes
immediately after restarting operation or turning on the main power.
Poor cooling or heating performance
• The air inlet or outlet of the outdoor unit is blocked.
• Doors or windows are opened.
• The air filter is clogged with dust.
• The louver is not at the correct position.
• The fan speed is set to low.
• The air conditioner is set
to the DRY or SLEEP MODE.
• The temperature setting is too high (during cooling operation).
• The temperature setting is too low (during heating operation). (heat pump models)
Feb 01, 2015 | Samsung AS18A6RB Air Conditioner
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Directions to reprogram hunter 952g
You need remote control.
Go to your circuit breaker or fuse box, and turn off the power to the fan you will be programming.
  • 2 Turn the fan's remote control over, and remove the battery compartment cover. Take out the remote's 12-volt alkaline battery, and set it aside.
  • 3 Match the DIP switches inside the remote's battery compartment with the DIP switches on the fan's receiver unit.
  • 4 Reinsert the 12-volt alkaline battery into the remote's battery compartment, and replace the battery compartment cover.
  • 5 Go back to your circuit breaker or fuse box, and turn the power to your fan back on.
  • 6 Press the "Hi," "Med" and "Lo" buttons on the remote control in quick succession. Complete this step within 20 seconds of completing Step 5. The remote is now programmed and ready to operate your fan.
  • Sep 06, 2012 | Hunter Dryers
    Remote stopped working, fan and light do not
    click the reset and turn off the fuse box and then turn on
    Feb 15, 2010 | Casablanca Fan 3245T Ceiling
    Casablanca fan stopped working suddenly, both fan & light
    You must 'reset' the remote. I've had it happen quite a few times.
    1. Turn off power to fan. Then back on.
    2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
    Sep 29, 2009 | Casablanca Fan Versa Touch2 W-72 Remote...
    Casablanca fan only runs at highest speed
    When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
    Aug 30, 2009 | Casablanca Fan Panama II 50" Ceiling
    My casablanca fan versa touch 2 does not respond to remote control - batery is fine, breaker fuse too. I recall having a same problem some time ago, forgot, how I fixed it - I know it was something with...
    Sep 04, 2008 | Casablanca Fan Versa Touch2 W-72 Remote...
    Our casablanca ceiling fan has power going to the fan and the remote works but the fan does not nor does the light
    If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
    Jun 25, 2008 | Casablanca Fan 3245T Ceiling
    Need a replacement fan speed potentiometer.
    Okay -- first off, I don't know where she got that number from, but that's idiotic.
    The variable-speed switch will provide different readings depending on where it's turned to. If the switch is busted ("open), it will typically display a reading of 'infinity' on your ohmmeter.
    And yes -- the best place to find a replacement is Radio Shack, since Casablanca discontinued them.
    HOWEVER---
    Casablanca's variable-speed ceiling fans -- specifically the "SlumberQuiet" ones, which were made from circa 1980 or 1981 to the early/mid 1990s when variable-speed was discontinued -- are well-known for breaking down. The problem is almost never the potentiometer (variable-speed dial). Rather, the problem is almost always the resistor which is mounted in the heat-sink inside the fan's motor housing. There are NO replacements left for these -- so Casablanca makes a "variable-speed to 3-speed conversion kit", which will convert your fan to a more normal 3-speed pull-chain (hi-med-low) setup.
    I hope that helps! If you have any other questions, please feel free to ask!
    Jun 16, 2008 | Casablanca Fan Dryers
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
