Question about Cuisinart Tob-40 Toaster Oven Broiler
CAN THE HEATING ELEMENT BE CHANGED
ONE ELEMENT IS SPLIT OPEN AND BENDING
The heating element on my Hamilton Beach toaster oven 31134 has a hole in the covering and smells when I use it. Is that safe? Can I replace the heating element?
The element is failing and while it will probably not catch fire, it is better to be safe than sorry and just replace it. Does not look like a replacement element is offered. Sears has this toaster oven for $22.49 + $6.99 shipping.
Dec 10, 2016 | Hamilton Beach Toaster Ovens
Heating element on toaster oven have mercury in them
No they don't. If they did it would be online and they would never get through inspection anyway. Mercury is expensive, but you do find mercury in all florescent tubes and compact florescent lamps in very small quantities. Toaster oven elements are radiant and have a metal element inside a ceramic glass tube.
https://www.google.ca/search?q=Heating+element+on+toaster+oven+have+mercury+in+them&sourceid=ie7&rls=com.microsoft:en-CA:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=bokqWOz-NoWN8Qe66IegDw
Heating element on toaster oven have mercury in them Google Search
Nov 15, 2016 | Toaster Ovens
Parts heating element
I received a new euro-pro ritisserie convection oven for Christmas and I just love it, but, the heat bars stopped heating. I miss it so much and don,t know what to do to fix it. Barb Tyrley
Oct 11, 2013 | Euro-Pro TO161 Toaster Oven with...
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Heating element no longer works. is there a fuse or is it the coil that's the problem?
I had the same problem and discovered it was the plug on the heating element was loose. I'd check continuity with a ohm meter across the coil. If it shows a closed circuit there isn't anything wrong with the element itself and could be as simple and cheap as tightening up the connector.
Dec 28, 2009 | T-Fal Avant Elite OT8085002 Toaster Oven...
BOTTOM ELEMENT DOES NOT WORK
If the top element is working, then it is either the element, the wiring harness , or the control board.
Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
The heating element must be removed and tested using a multimeter.
The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
If the element has continuity, test the wiring harness, then replace wiring harness or control board.
All the test must be done by a trained repairer, strictly observing all health and safety rules.
Regards.
Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Cuisinart Tob-40 Toaster Oven Broiler Logo
49 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
