How to clear 1.flag clear - Office Equipment & Supplies
Have bought 2nd hand casio TE 8000F. 'operator mistake' constantly appears. when i remove the slip cover this message clears and new instructions INIT appears with 1.Flag Clear or 2. Init 2. What should...
Make sure flag clear is highlighted (use the arrow buttons) then press yes button. It should check files then place you in REG mode. It might have had a flat memory battery so make sure you leave it on for 24hrs to charge
Nov 23, 2013 | Casio Parts Cash Register PC Desktop
Error ##334., its my problem
The error code ##334 represents a EEPROM check error. The manual says this means the Printed Circuit Board may need replacing, however, try this procedure.
Insert paper into machine.
1)To enter service mode press Menu, copy, #
2) Select Test Mode with the + or - keys
3) Press OK
4) Press 8, lcd shows 'Please Wait', after wait, press 3, the lcd then alternates between 3-0 (EEPROM clear), and 3-1 (Purge flag)
5) When EEPROM clear (3-0) shows in lcd, press 0, then OK, then Stop then press the OFF button.
Repeat the above from Step1 to step3
in step 4 this time reset the Purge flag by pressing 0 when 3-1 shows in the lcd, OK, Stop, Off.
If the red fault light is still blinking press Resume.
hope this helps
Sep 05, 2011 | Canon SmartBase MP730 All-In-One InkJet...
I have problem with my canon copier image ready 5020. error E000004-0000 how do I fix it i'd tried to press 2&8 but its said "Download Mode"
Error E000004 is a fuser related code and is most parts just caused by a paper jam in the fuser area. Before you begin to try and clear the internal flag you must make sure there is no paper or no obstruction stuck in the fuser area. With the power off rotate the fuser model handel to see if any aper or obstruction exsists. Clear it carefully if there is. At any time NEVER USE a knife or sharp object to clear a jam. Common sense I know, but few practice it. Once you clear the paper jam you can see if clearing the flag is the magic you need. If the next stages fail contract a local Canon trained tech to troubleshoot the real source of the error. Clear the error flag do the following steps DO NOT touch any thing else DON'T adjust any numbers. Turn machine on. When main screen apprears press Additional Functions button (*) let go. Press 2 and 8 together let go. Press Additional Funtions button (*) again. Screen should say Service Mode Level 1. Press these screen buttons in the following order. Copier, Functions, Clear, ERR then press OK in lower right corner. Machine will apprear as if nothing has happened but it has. Shut machine off at side. Turn on. Flag is cleared. If code reappears get professional help. This is a fuser code therefore we don't want a fire or anything else happening. Doing this clear you have 30 seconds before macine shuts off. It takes timing. Good Luck.
Jun 28, 2011 | Canon imageRUNNER 5020 Copier
How can i cancil error 0004 ?
To clear the error code you must enter service mode level 1 first. Once in service mode you choose in the following order Copier>Function>Clear select ERR and push ok. At this point it would apprear nothing has happened but in fact the error flag has been cleared. Shut the machine off. Now turn on. If your error was minor and your cleared the cause of your error E000004 then the machine will operate as it did before the flag went up. If you get the error code again look for a Canon trained tech in your area to correct the issue. If you do not know how to get in to the service mode level 1 your best to search for entering service mode canon. As I don't want to promote persons without expertise entering the machine service and adjusting things without any backgound. Good Luck
Jun 25, 2011 | Canon imageRUNNER 5000 Copier
I have just baught a second hand casio TE8500f cash register and every time i turn it on it displays init 1.flag clear 2.init2 and every button i press it then displays operator mistake
Highlight "flag clear" and press YES button. If it still does not work, you have a flat or (usually) faulty memory battery and it will need to be RAM cleared then re-programmed.
If anyone needs more informaton on the Casio TE-8000f or TE-8500f, the manuals are here:
Programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-7000S_and_TE-8000F_and_TE-8500F_programming_manual.html
Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-7000S_and_TE-8000F_and_TE-8500F_service_version_2_manual.html
Feb 11, 2011 | Casio Parts Cash Register PC Desktop
How do i clear error c1300 on minolta Di 181
C1-3000 Registration Sensor On JAM RAP (Tray 1 Feed)
After the Tray 1 Feed Clutch turned On, the Registration Sensor did not turn On within the
specified time.
Initial Actions
Refer to BSD 8.1/8.6.
Power OFF/ON
Procedure
Check the Transport Roll for wear and paper powder. The Transport Roll is ok.
Y N
Replace the Transport Roll.
Check for foreign substances, distortion and paper powder in the paper transport path. No
foreign substances, distortion or paper powder are found in the paper transport path.
Y N
Clear away the foreign substances and paper powder. Correct the distortion.
Execute Input/Output Check[8-5 Registration Sensor]. Manually activate the actuator of the
Registration Sensor (PL 2.4). The display changes.
Y N
Check the connection of P/J104. P/J104 is connected correctly.
Y N
Connect P/J104.
Check the wire between J104 and J403 for an open circuit or a short circuit (BSD 8.6 Flag
1/Flag 2). The wire between J104 and J403 is conducting without an open circuit or
a short circuit.
Y N
Repair the open circuit or short circuit.
Measure the voltage between the MCU PWB P403-B15 (+) and the GND (-) (BSD 8.6
Flag 2). The voltage is approx. +5VDC.
Y N
Replace the MCU PWB (PL 9.1).
Measure the voltage between the MCU PWB P403-B14 (+) and the GND (-) (BSD 8.6
Flag 1). Place paper in front of the Registration Sensor. The voltage changes.
Y N
Replace the Registration Sensor (PL 2.4).
Execute Input/Output Check[8-12 Tray 1 Feed Clutch ON]. The Tray 1 Feed Clutch (PL 2.3)
can be heard.
Y N
Check the connections of P/J217 and P/J415. P/J217 and P/J415 are connected
correctly.
Y N
Connect P/J217 and P/J415.
Measure the resistance of the Tray 1 Feed Clutch (PL 2.3) (BSD 8.1 Flag 2). (Between
P217-1 and P217-4). The resistance is approx. 186Ohm.
Y N
Replace the Tray 1 Feed Clutch (PL 2.3).
Check the wire between J217 and J415 for an open circuit or a short circuit (BSD 8.1 Flag
2). The wire between J217 and J415 is conducting without an open circuit or a short
circuit.
Y N
May 19, 2010 | Minolta DiALTA Di181 Printer
TE-8500F says Device ID Not Set when I try to use Credit
I have a few questions.
1. where did the Datacap come from, or was the register programmed to use the datacap?
2. there is a place in pgm3 wheere you assign devices, its called I/O and in there you have to enter the right codes for it to work. Also after its been installed you must do a FLAG CLEAR.
3 To do a flag clear on an 8500 on the right side turn the machine off hold down the REC FEED button. While holding down the buton turn the machine back on and wait till the screen comes back and press subtotal. after that it will go through a bunch of funny looking stuff and the it will come to screen where it asks if you want to flag clear or init 2 use #1 flag clear and press yes. sign on and test.
Chris
May 15, 2009 | Casio Parts Cash Register PC Desktop
Wont let us change anything comes up with operater mistake
Hi.
Have you tried a flag clear? That might allow you to clear the buffer if it is a REG buffer overflow. as for pricing, you should just be able to go into prog 1 and change PLU prices.
If you are not sure how to flag clear it, just let me know.
Mark
Apr 09, 2009 | Casio Parts Cash Register PC Desktop
Bin 1 full message will not clear when paper is removed
Check the Bin Full sensor flag. That is the flag that flips each time a page comes out of the printer itself.
If that flag is broken, or is malfunctioning you can get that message.
Dec 19, 2008 | Lexmark T632 Laser Printer
jasbo
jasbo
