Question about Kitchen Ranges
My partner left the grill on on my cooker and now the grill won't stay on and there is no gas going through the bottom oven..any ideas what the problem might be?
    Problem Solver:
  • 7 Answers
Could be any number of possibilities, The user manual for your particular cooker (try Google the model number if you haven't got it) will have instructions on how to reset the cooker if it is a user feature.
It is very possible that a safety device has operated, possibly an overheat fail-safe. Such devices are internal, some are re-settable, others self destruct and therefore must be replaced, They can be separate components or may be an integrated feature of another component. They are sometimes a 'last resort' safety cut-out that operates when the design limitations of the appliance have been exceeded. They are often devices fitted to protect against injury or fire and may not necessarily protect against damage to the appliance itself. So even if the fault is due to the operation of a safety cut-out there is still a chance that any damage to your oven is repairable. The appliance should be professionally examined and tested before replacing the cut-out and recommissioning the cooker.
Posted on Nov 17, 2014
  • 183 Answers
SOURCE: The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Posted on Jul 28, 2007
ronaldo1
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Posted on Feb 15, 2008
SOURCE: Oven failure
Panick Over!!
We had to pull out the oven and discovered the problem was a blown 3amp fuse in the plug at the back of the cooker! A bit of a scramble for a spare fuse but at least we're back in action!
Posted on May 27, 2008
  • 1462 Answers
SOURCE: I have a Belling 755
almost certainly the thermocouple is faulty
Posted on Oct 08, 2008
jumptrout51
  • 3361 Answers
SOURCE: Oven ignition: gas goes out as soon as control knob is released
Replace the oven thermocouple.
Posted on Mar 15, 2009
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
Oven failure
Panick Over!!
May 26, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
