Question about Coffee Makers & Espresso Machines
I have a Miele CVA 4085 coffee machine. Fault 73 showed up so I cleaned the brew unit, but it won't go back in. I think I need to realign it, but I can't get back to the main menu. I would be reall
I have a Miele CVA 4085 coffee machine. Fault 73 showed up so I cleaned the brew unit, but it won't go back in. I think I need to realign it, but I can't get back to the main menu. I would be really grateful for any advice.
4 Suggested Answers
SOURCE: miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Posted on Apr 09, 2009
  • 128 Answers
SOURCE: I have a cva coffee machine it seems like the brew
F73 is a bad brew unit. The cva 4070,4075,4060, and 4066 are designed to use espresso beans.
If you use an oily bean such as Starbuck's french roast, it will clog the filter in the top of the brew unit. If you catch it in time, you can just replace the brew unit. If you run the machine with a clogged filter long enough, you have to replace the brew unit and gearbox together.
Sometimes if you work with the tech support department, they will send you a brew unit to install yourself. If you live in an area that has Miele factory support, you may just want to get a service call. It is very important to rinse the brew unit every 24 hours, and to use the cleaning tablets in the trap door( not the descaling tablets) if not, the coffee oils build up and turn into a tar that will clog the brew unit. They run about 300 dollars so they are worth doing the maintenence on.
Posted on Nov 21, 2010
justinbur167
  • 257 Answers
SOURCE: my miele cva 4075
Hello Loriktarrant,
I understand the your Meile CVA4075 is showing you an F73 code. This code means that the brew unit needs to be cleaned. Here is a link to the owners manual on page 40 it shows you how to manually remove and clean the brew unit. The other issue you are having with the milk and coffe not being hot enough could be to the machine needing descaled.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man enter the numbers in the box and click download.
Thank you for choosing FixYa.com
Justin
Posted on Mar 13, 2011
Miele cva 4075 stuck brewing unit
http://mielerepaircenter.com/miele-coffee-maker-repair
Sep 07, 2014 | Miele CVA4070 Coffee Maker
Cold coffee. Real programming mode Miele CVA 4085?
Hi Pepijin,
I do have this site where you can download manual for you to review it by yourself in case you encounter some issues as well. Hope it helps.
Miele CVA 4085 Operating And Installation Manual Page 50 Setting The...
Apr 25, 2014 | Miele CVA4070 Coffee Maker
Miele brew unit
You should be able to, If you can remove it and providing there are no Electrical parts, then soak in a white vinegar and water solution.
Or a Descaler.
Jan 28, 2014 | Coffee Makers & Espresso Machines
I have a Miele Coffee System CVA 4075. Kept getting fault 73 message. Long story short, the Brew unit is out of place. I somehow need to get it back into the basic position. When I turn it on now it reads...
I have a Miele CVA 4085 built-in coffee maker which had a similar problem to this and other problems where it gets locked into a state and won't let you do anything else. I my case it says Cleaning and it demands you empty the drip tray even though it is empty. In my case it was at the end of a cleaning cycle and refused to go on. Cutting power and restarting always had it return to the same state: Cleaning, empty drip tray.
I cleaned the contacts on the drip tray and at the back using the nail file, still nothing. Then I found a post on how to get into the programming menu, which on the CVA 4085 is this:
Open the door and switch off the power with the rocker switch on the top left.Wait at least 5 seconds.
Switch the rocker on then VERY QUICKLY close the door and hold the clear button for 5 seconds.
With your other finger touch the ON button then pull both fingers away at the same time.
Do 5 rapid presses of the clear button but hold your finger down on the last press and keep holding it down until the programming menu comes up.
Do not press the reset button that you see at the top of the menu (unless your German is quite good or you have access to Google Translate).
Scroll down until you find the reset cleaning button and select it. Once you have confirmed you can then exit programming mode by powering off.
It took me quite a while to get to this point, but at least I can now recognize the German word for drip tray.
Oct 07, 2012 | Miele CVA615 Espresso Machine
Meile cva 4085 not brewing no error
Hi. i need more info. does it turn on, does it heat, make steam, make any noises?
Sep 24, 2011 | Miele Coffee System
My miele cva 4075 is not heating the frothed milk or coffee up as well any more...sometimes a Fault 73 shows on the screen..i have cleaned the brew unit with tablets and water etc...what should i do next?
Hello Loriktarrant,
Justin
Mar 12, 2011 | Miele Coffee System
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
I have a cva coffee machine it seems like the brew unit is jamed it makes a buzzing noise like it is descaling itself , I have cleaned it and checked the shoot for alignment it makwes the noise and then...
Nov 21, 2010 | Miele Coffee System
Getting Fault 73 for my CVA 4070 at start-up. Have removed the brew unit to ensure is clean and plastic piece -- shaped like a block "M" or block "W" - is in the "W" position. Have tried a manual on and...
I have had the same fault 73. Miele is coming out to replace the drive and the brew unit. SHould be a $700 repair. Thank God for warranties. I'll et you know the end result once repairs are complete.
Jan 09, 2010 | Miele CVA4070 Coffee Maker
Miele coffee maker cva 4070
Feb 27, 2008 | Miele CVA4070 Coffee Maker
Coffee Makers & Espresso Machines Logo
187 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
