I purchased 2 inch one touch blinds from green mountain vista they are great but one problem they are crooked when you look at them they hang lower on the right side. Anyone else having this problem??
I purchased 2 inch one touch blinds from green mountain vista they are great but one problem they are crooked when you look at them they hang lower on the right side. Anyone else having this problem?? I used a level and the installed top part is perfectly straight. I bought 3 and I am having the same problem with them all. I also watched the video and they are installed correctly. Any help??
  • 1139 Answers
Hello Renee, You have a convergence problem, but you are adjusting the wrong system. You need to adjust the convergence rings first ok You need a dot and crosshatch generator to properly set convergence for this set. Connect the generator set the TV to channel 3 and turn on the generator set it to dots adjusting the convergence try to get the center dot RGB all together and then adjust for the outer edges using the convergence board. the use the crosshatch to adjust convergence along the lines of the crosshatch pattern. Remember use the rings first and the the convergence board adjustments.
Posted on Sep 24, 2007
  • 81 Answers
SOURCE: veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Posted on Apr 09, 2008
SOURCE: Yellow line on right side of screen
Go to this website and read what it has to say, your TV's have major problems.
Posted on May 22, 2008
SOURCE: Sony KP-57WS510 Convergence issue?
There should not be a need to replace the chip if the fuse below the convergence chip is blown. Check to see if there is a short in the convergence output (after the fuse). If nothing is seen then replace the fuse and see if it works.
Posted on Jun 20, 2008
  • 4 Answers
SOURCE: Philips Go Gear MP3/Video Player 2 GB (Model SA3125)
The Phillips Go Gear is not compatible to Windows Vista, and there is nothing one can download to make it compatible. I contacted Phillips, and they said that there are no plans to update the software so that it works on Vista. Pass this to everyone that is having a similar problem. Contact Phillips on their website, and request that the Phillips Go Gear software be updated to include Windows Vista. If more people raise a stink (especially threatening never to buy Phillips products), maybe something will be done.
Posted on Oct 19, 2008
Metal blind foot hem 6217c
The 6217C doesn't have a blind hem foot. You need the General Purpose (low-shank) foot, the General Purpose Needle Plate and the blind hem guide (part number 381213). The guide gets secured by the screw that holds the presser foot shank. This site, , has the blind hem guide available. This metal foot might fit your machine: .
I hope this helps.
(who has a similar blind hem stitch guide for my Singer Touch & Sew. I haven't gotten the hang of it yet.)
Feb 10, 2014 | Sewing Machines
My samsung rb215labp lower freezer model . i bought this refrigerator 2 weeks ago it was cooling great thats why i bought it they had ice cold water in it and it all seemed good for 2 weeks then the...
Do you hear your fan motor running? if not that could be your problem if there is no air circulation to the refrigerator is going to ice up and it will be warm in a short time...good luck
Jun 16, 2011 | Refrigerators
Red an green lines across the tv about every two
Sounds like you have retrace lines in your picture. It may resemble something like window blinds, but slanted to the lower right. You most likely have a bad crt or the AKB circuit is bad. This most likely needs a technician to adjust the G2's to see if it can be balanced.
Apr 29, 2009 | Sony KP-51WS500 51" Rear Projection...
G-Pen F610 blind spot (pen won't move over particular section)
Sometimes it is caused by a metal plate coming in contact with the sensor pad inside of the tablet. It is only fixable by dismanteling the tablet and putting an A4 sheet of paper between the back side (the one that has the metal plate which can be the culprit) and the green pad (do not touch it!). This issue usually appears after continuous use when the green sensitivity pad is pushed down a little and is short-circuited by the metal pad on the inner side.
Dec 28, 2008 | Genius G-Pen F610 (31100050100)
I read another entry and you have to hold down the red and green button and click your stylus into the bottom little button beside where you plug your phone in to charge.
It didn't fix my problem though which is similar to yours.
Sep 21, 2008 | HTC Touch P3450 Smartphone
Green colors are seperated from rest
You might have a bad green convergence output IC either loose from the circuit board or open internally OR shorted. Stargazer
Apr 22, 2007 | Pioneer PRO-99 TV
Convergence problem, lower left corner fixed green gun convergence bows upward
You have a componet out of tolerance in the green drive circuits, resistor or capacitor. If you have the service manual you should be able to take some raedings off the test points for the circuit and be able to track it down. I am enclosing a link where you can purchase the service manual for that set for 10.99. They will mail it to you unless you go back to the site and request that they email it to you by clicking on the contact us link. They also offer unlimited free support if you purchase your manual. I am one of their support techs. Hope this helps. Heres the link
Dec 27, 2006 | Pioneer PRO-119 60" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
