Question about Plumbing
How do I fix hot water handle that is leaking on Moen Banbury ca87000 sink
Hot water is leaking through the spout
    Problem Solver:
  • 15 Answers
The valve cartridge needs replaced. Those can be purchased at most home improvement stores, such as Home Depot. Or, it may be under warranty.
http://www.moen.com/replacement-parts/search
Posted on Nov 17, 2014
  • 82 Answers
SOURCE: I have a slow leak coming from the spout
ooops, didn't mean for that to be a request, sorry...It was a solution. Although, if you dont want to deal with Moen, you can get one at your local plumbing suplly store. I recommend taking the old one with you (make sure you shut the water off first!). Again, good luck
Posted on Sep 03, 2009
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
  • 94 Answers
SOURCE: water leaking from tub spout when shower is on
yes they do,part #1224
Posted on Apr 27, 2010
Dplumber
  • 119 Answers
SOURCE: my moen two handle kitchen faucet only leaks at
There are several O-rings that you can replace. Visit Moen's website to determine your faucet and the necessary replacement parts. You can call them once you have found your faucet and ask for assistance as well. They are very helpful.
Posted on Sep 10, 2010
  • 2841 Answers
SOURCE: I have a Moen Banbury
The gasket under the aerator more than likely needs replacing. First make sure it is tight. If it is tight then remove the aerator by turning counterclockwise and check the gasket. Replace it if it has deteriorated or is cracked. You can buy a replacement at any hardware store.
Posted on Dec 13, 2010
How do I adjust a handle on a 4inch two handle moen bath sink faucet? It does not align properly when turned off. It is the Banbury style.
turn off water Remove set screw on side of handle. once the handle is removed try to realign. if that does not work remove the cartridge nut and reposition the cartridge as to set properly. the cartridge normally has a tab on it set in the groove of the valve body.
Jan 18, 2017 | Moen Plumbing
Hot water is leaking from the spout of Banbury ca87000 sink
The filter on the tip is clogged and loose
Nov 17, 2014 | Plumbing
How to fix Moen Banbury model 87690SRS kitchen faucet ?
There is no way to tighten spout from top of sink. If you slide in cabinet and look up at the bottom of the faucet (spout ) you will see a nut on the threaded shaft of the spout hanging below in cabinet. With a basin wrench, kind of like a spring loaded pair of channel locks with a long extension arm and t-handle, you get it around the nut and tighten it clock wise on the shaft. You may have to disconnect the faucet valve ( handle part of faucet) from the bottom of the spout before tightening. Note...be sure that the jaws of your basin wrench are firmly around the nut only as not to mar and gouge the threads on the spout shaft. It is also helpful to have someone else hold the spout in position at the top side in order to tighten it properly. Some of the moen models (depending on place of purchase) may have a nut with set screws in it. You get the nut as tight as you can by hand and with a screw driver tighten the screws which will be visible and the heads will be facing down at the sides of the spout shaft. If you can't seem to locate what I am describing post again and I will try to locate a diagram for you.
Apr 26, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
Moen banbury faucet repair
I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
The links to the installation guide and exploded diagram are:
http://www.moen.com/shared/docs/instruction-sheets/ins2224.pdf
http://www.moen.com/shared/docs/exploded-parts-views/87017pt.pdf
Jan 18, 2014 | Plumbing
Had new water heater installed. Ever since, there is very little water flow from both hot and cold faucets of both (dual) sinks in 2nd floor bathroom. Faucets are Moen 9000 M-PACT type. Could air be t
check the aerators on the faucets. i know after i change a hot water tank there is always some crud that comes through the lines and gets stuck in the aerators, they are the part that holds the screens in place on the spouts.
Aug 14, 2012 | Moen Plumbing
I replaced the cartridges in my moen kitchen 2 handle faucet.I used danco 6s-1h/c. the hot side works correctly. the cold side just dribbles out. no idea how to solve this one.
by dribble out I guess you mean that the water is not flowing out the way you want?
first thing I would do is remove the coldside cartridge and test the water flow to that point. If the water is free flowing ( yes its a bit messy) use a second person one to open the valve ubder the sink the other to cup over the top of the open side of the faucet.
if that has good flow then while the cold is still openhold you hand over the spout and turn on the out water to us that to back blow the tube that goes to the spout.
Hope this works out for you best of luck
Tom
Sep 12, 2011 | Moen Banbury Collection 2 handle Kitchen...
Sep 03, 2009 | Moen 4621 Chateau 1 Handle Bathroom Faucet...
Plumbing Logo
172 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
