Question about Plumbing
I will refraze my question,How do I know what size of shut off angle valves to purchase for my bathroom and kitchen before i take them off to replace?
  • 4 Answers
Ya need to know what size and type of lines are running to your fixtures. (Copper, Pex, Iron, 3/8, 1/2", 3/4" ect) then the other end for faucets most common is 3/8" compression to 1/2" FIP feedline..
Posted on Nov 17, 2014
Why do we have hot water in one bathroom and not the other or kitchen
The pipe feeding those zones may be broken or shut down. Check out any and all valves in the hot water circuit.
Sep 07, 2017 | Water Water Heaters
What is the most usual size of angle shut off valves for bathroom and kitchen?
The most common size is 1/2" copper x 3/8" compression.
The 1/2" side connects to the water line sticking out of the wall. The 3/8" compression is connected to the supply line on your faucet
Nov 15, 2014 | Plumbing
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Where are the best place to purchase range hoods overseas?
OPPEIN is offering custome kitchen cabinets, wardrobe, bathroom products, kitchen appliance, kitchen accessories, range hoods, and commercial kitchen equipment worldwide.
Oct 22, 2012 | Kitchen Ranges
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
Kitchen and bathroom faucets do not get hot,hot.Lukewarm at best.
ok the way it works man is the box aka power vent the gas valve wont open until the power vent is open u can manualy open the powervent witch will open the gas valve to turn on the piolt light and in about 30 sec the main burner will kick on now if the powervent is opening the the pilot light isnt lighting then u need to replace the thurmole cuple witch sences the pilot light is on if it doesnt see the pilot the it shuts the gas valve off so it doesnt fill ur house with gas
Dec 28, 2008 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Roadliner valve stems
motorcycle valve stems are all the same size. Probably somewhere like JC Whitney would have them
Nov 10, 2008 | 1992 Aprilia AF1 125 Futura
How To Connect Sinks Drain
No matter what type of sink you purchase, the drain and water-supply connections are generally installed in the same way. Hand-tighten a female adapter onto the drain stub-out at the wall. Slide slip nuts onto the drain arm and the sink's tailpiece. Fit a P-trap in place and tighten the slip nuts by hand. Connect flexible water-supply tubes onto the faucet's tailpieces, and route them to the shut-off valves. Tighten coupling nuts with an adjustable wrench. Remove the faucet aerator, turn on the water, check for leaks at the shutoff valves, and then turn on the faucet to check for leaks in the drain assembly. Replace the aerator.
Aug 27, 2008 | Blanco 510-879 Single Bowl Undermount...
Plumbing Logo
59 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
