Question about Sharp Used AR-M207 Copier Printer Scanner
How do I resolve the problem on my machine that is bringing the code: F2-04
    Problem Solver:
  • 18 Answers
Panel problem is
Posted on Nov 23, 2014
C0070 machine trouble
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and if needed open then close the front door to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Minolta EP4000/5000 CS/PRO Copier
Tip
Konica Minolta Copier service code C0070 C-0070
on Jan 04, 2010 | Office Equipment & Supplies
It doesnt print the first page and its a minolta cspro 3000 and the error code is c0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
Sep 29, 2010 | Minolta Office Equipment & Supplies
Minolta di250 error code c0070 this error code
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
Sep 28, 2010 | Minolta DiALTA Di250 All-In-One Laser...
We keep getting code that says uL, the machine keeps getting unbalanced and then bringing up the code , it is also dipensing water during the spin cycle, we had a service man out and he replaced the drain...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
MACHINE SHOWING THE 0070 CODE PROBLEM
If the code comes back after the cartridge is re-installed then there is either a problem with the cartridge or with the toner bottle drive.
Jun 30, 2010 | Minolta EP4000/5000 CS/PRO Copier
Printing Problem.
RPC server may not be started issue the following command to start the RPC server:
net start rpcss
I successfully ran the command to resolve a previous problem. keep me posted
Jul 23, 2009 | Computers & Internet
Have a ricoh aficio 450 and there is error code sc 623?
1. With the machine turned off. Go to the back of the machine and disconnect the cable that goes to the paper deck.
2. Turn on machine.
3. Turn off machine.
4. Reconnect the cable.
5. Turn on machine.
6. If problem continues you need the BICU
Dec 17, 2008 | Ricoh Aficio 450 Copier
F06 error
Check the drain pump. There may be something jammed it it, causing it to overload, and bringing up the fault code.
Oct 25, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Sharp Used AR-M207 Copier Printer Scanner Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
