Question about AO Smith Miller / LSI / Home / Nordyne Replacement Furnace Motor 1/5hp 1050 RPM 115 volts OML64
Turn unit on blower will not work unit just makes a noise
  • 10,291 Answers
The start capacitor or the centrifugal switch inside the motor are not working.
Posted on Nov 17, 2014
Turning the heat on makes lot of noise
If the blower motor is noisy, the bearing may be getting bad inside the blower. This will require replacement of the blower motor unit. In some cases, foreign objects can fall into the motor casing assembly also making a noise. The motor will need to be removed for inspection
Jan 14, 2016 | 2007 Nissan Sentra 2.0 SL Sedan
Maytag neptune dryer has noise inside of drum what is it
it may be the motor , debris stuck in blower wheel or bad rollers . stat be removing the belt and turn the unit on if makes noise you have a faulty motor if there's not noise replace the belt and cleanout the blower wheel .good luck APPLIANCES R EN
Feb 23, 2013 | Maytag Dryers
My blower works, but makes a noise like a card in bicycle spokes..what could be the proble?
sounds like there is something stuck inside the blower motor --- same thing happened to my Jeep and it turned out to be a dead mouse inside the blower box.
remove the blower box and inspect.
c...
Feb 05, 2011 | 1997 Jeep Grand Cherokee
Whenever I turn on my air conditioner, my car makes a roaring or rubbing noise. What is it?
Sounds like the clutch in the compressor which would usually be in the front lower portion of the engine on a pulley on the front of engine (passenger side on front wheel drive cars - and tubes are connected to it.  When engine is off spray with some lube but not on belt - allow to drip of for couple minutes.
Try that couple times and start car in between times using the air conditioning.  Not sure if you can replace the clutch unit or have to replace the compressor as a unit which would lose the Freon or R2 or whatever the new stuff is called now...
Hope that helps.
East Coast Canada Rocks!!
Jun 11, 2010 | 1998 Chevrolet Cavalier
A/C chirping noise Camry 1998
If there is chirping noise then some object in the blower motor or the blower is making noise due the frictions b/w the walls of the blower motor unit ,you need to check the blower motor .....
Good luck...
Jan 19, 2009 | 1998 Toyota Camry
York P3HU Gas Furnace Blower wheel makes noise and vibrates
yes you have a bad blower wheel the fins are crimped to the disks, if you can take the blower assembly out just watch the wiring and take the motor out of the center of housing away from blower wheel and when taking out the wheel remember the diriction of the wheel
Dec 11, 2008 | Carrier 38CKC042 Air Conditioner
Goodman GMP075 Problem
check the mfds of the capacitor.if its ok you need a blower motor.
Aug 09, 2008 | Heating & Cooling
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
AO Smith Miller / LSI / Home / Nordyne Replacement Furnace Motor 1/5hp 1050 RPM 115 volts OML64 Logo
76 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
