Question about Crown Parking Light Passenger & Driver Side Front With Bulbs Clear J5752771
How do i replace o/side front side lamp bulb Hyundi i10 2013
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
How to replace the left front turn signal bulb?
Remove the front fender liner to gain access to the front side marker lamp. Remove 3 screws from park lamp and pull out lamp. Twist the bulb socket and pull inward to replace the bulb...Here is a picture of it....Hope this helped you ?michael_cass_316.jpg
Jul 14, 2011 | 2006 Buick LaCrosse
How do I change a brake light bulb in a 1999 c70 volvo?
Welcome to FixYa.com
Brake Lamp Replacement
Location of the lights
The illustration shows the locations of the lights on the RH side. The LH side is the same but
mirror-reversed.
The lights have the following functions:
- 1 +1 = Parking light Fail light
- 2 = Reversing light
- 3 = Fog light LH side only (LHD cars)
- 5 = Direction indicator
- 6 = Brake light
Tail light changing bulbs
Ignition off.
Open the cover in front of the tail light
Undo the wing nut and take out the lamp holder.
Change the defective bulb.
Fit in reverse order.
Check that all bulbs lamps are intact and in working order.
Replacement of tail light cluster
Note! If a new tail light is to be fitted, the sleeves must be ground down 1.5 mm.
Open the cover in front of the tail light Undo the panel partly in front of the tail light Unplug the
connector for the tail light Undo the four nuts securing the tail light see illustration.
Pull the tail light straight out. Fit in reverse order
Note! check the sealing and fit on reassembly.
Check that all bulbs lamps are intact and in working order.Thank you for Using FixYa.comKind Regards, LeeYour FixYa Expert and Master Technician
Jan 27, 2011 | 1999 Volvo C70
My rear marker/ running lights are out and i need to know how to get to them
Signal and Marker Lights Removal & Installation To Remove:
  1. Remove or disconnect the following:
    • Screw from the side marker lamp.
    • Side marker lamp from the front and/or rear bumper fascia.
    • Bulb/socket from the side marker lamp.
    • Bulb from the socket.
To Install:
  1. Install or connect the following:
    • Bulb to the socket.
    • Bulb/socket to the side marker lamp.
    • Side marker lamp to the front and/or rear bumper fascia.
    • Screw to the side marker lamp. Tighten to 2 N.m (18 lb in ).
Jan 08, 2011 | 2002 Pontiac Sunfire
How do I replace the front left (driver side) headlight? I have removed the cap and the electrical, but can't figure out how to remove the bulb so I can put a new one in. Your help is appreciated.
  1. Disconnect the negative battery terminal.
  2. Remove the head lamp mounting bolts, then disconnect the lamp connectors.
  3. Replace the head lamp bulb(A), position bulb(B) and turn signal bulbs(C).
    Head lamp bulb(A), position bulb(B) and turn signal bulbs(C)
  4. To install, reverse removal procedure.
Dec 12, 2010 | 2005 Hyundai Tucson
How do I change the back turn signal on my 2001 ford taurus
DIY - 5 Minute Turn Signal Bulb Replacement This is very simple to do. First you will need an 8mm socket and wrench to loosen one bolt. Second a good long flat head screwdriver. There are two black metal folded tabs behind the headlight assembly and one 8mm bolt holding it in plae at the center point of the front of the car. Loosen the bolt and remove. Use the screw driver to pull up the metal straps and then slide forward the entire assembly. This will slide easily unless your front bumper has been bumped! That will make it a little difficult to slide if it is out of alignment. If it was never bumped than this should take all of 5 minutes.
Replacing front parking lamp/turn signal/cornering lamp bulbs
  1. Remove headlight / lens assembly per below steps mentioned later
  2. Rotate the bulb socket of the offending bulb counterclockwise and remove from the lamp assembly.
  3. Carefully pull bulb straight out of the socket and push in the new bulb
  4. Install the bulb socket into the headlight assembly by rotating it clockwise
  5. Re-install headlight assembly - hold snugly into place until the brackets line up and retainer pins can be pushed down
To replace headlight bulb:
  1. Make sure headlight switch is turned OFF.
  2. Remove the bolt at the end of the headlamp housing.
  3. Pull the two black tabs with the L shaped bracket toward the back and then up and pull out(Located at the back of the headlamp) to release the headlamp assembly from the vehicle and pull headlamp assembly forward.
  4. Disconnect the electrical connector from the bulb by pulling it.
  5. Remove the bulb socket retaining ring by rotating it counterclockwise.
  6. Remove the bulb from the lamp assembly by pulling straight back.
    Do not twist, as there are alignment slots built into the lamp assembly socket.
    It may take some effort to remove the lamp because it has a rubber o-ring type seal - try a bit of wiggling side-to-side
  7. Insert new bulb into headlight assembly - don't touch the glass - use gloves, paper towel, or similar
    Make sure that the flat surface of the bulb socket is facing upward, and is firmly seated
  8. Re-attach retainer ring by rotating clockwise
  9. Reconnect the electrical harness
  10. Re-install headlight assembly - hold snugly into place until the brackets line up and retainer pins can be pushed down
NOTES
  • Do not touch the glass of the new halogen bulb - the oils in the skin will shorten the life-span of the new bulb, or possibly cause the bulb to explode when first turned on
    If the bulb is accidentally touched, it should be cleaned with rubbing alcohol before being used.
Additional Information1996-2005 Bulb Numbers:
  • FRONT Turn-signal - 3457 AK (amber)
  • Headlamp - 9007 QL (9007LL optional)
  • Tail lamp/brake/turn lamp 3157
  • Tail lamp/brake lamp (wagon) 3157
  • Rear turn lamp (wagon) 3456K
  • Backup lamp 921
  • Backup lamp (wagon) 3156
  • License plate lamp (2) 168
  • High-mount brake lamp (2) 912
  • Rear side marker lamp (wagon) (2) 168
Feb 24, 2010 | 2001 Ford Taurus
Tail lights work on both sides. turn signal and
Sounds like you need to replace the drivers brake/tail light.
Dec 14, 2009 | 1998 GMC Sierra
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
My left indicator isnt working,the rest are though
need more info ??does it work with hazzards on ??all four lights?'
Jun 14, 2009 | 1999 Volkswagen Passat
Difficulty with replacing fog lamp bulb on 2001 Hyundai XG300
Remove the headlight and put it in from the top.
Dec 30, 2008 | 2001 Hyundai XG300
Crown Parking Light Passenger & Driver Side Front With Bulbs Clear J5752771 Logo
151 people viewed this question
Top Crown Car Audio & Video Experts
Dennis Key
Dennis Key
Lawrence Oravetz
John
John
Are you a Crown Car Audio and Video Expert? Answer questions, earn points and help others
