Question about Exercise & Fitness
Hello, can you advice me how to repair treadmill?
Hello, can you advice me how to repair treadmill? We bought Power tech olympian treadmill week ago and it doesn't work properly. The running belt is not going fluently, and we think there can be something wrong with motor, becouse we can hear a bit weird sound when it's turned on. And incline just stopped somewhere in the middle and we can't get it totally down. Here I'm sending a short video how the running belt is going, and photo with zero number incline on display, but you can see it's not flat and it just don't going down. Thank you for any help. Daniela
    New Friend:
    Problem Solver:
  • 6 Answers
Hi! I think u shouldn't tamper with it coz its too soon take it back to where u bought it so they can chek it out for u it still has gaurantee coz its not even a month
Posted on Nov 18, 2014
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: treadmill belt stopped
as soon as i press the speed button on my weslo m5 the belt seems to jolt forward then stops and everything goes off can anybody help on wot this problem could be
Posted on Aug 06, 2009
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
2manyhobbies
  • 129 Answers
SOURCE: I have an Epic t60. The incline stopped working. I
Try to recalibrate the incline. Start the machine running, press the incline up button, then pull the safety key off. Release the incline up button and replace the safety key. The treadmill should go to maximum incline then minimum. after calibration is completed, retry the treadmill operation.
Posted on Jan 11, 2011
ercupa190
  • 12223 Answers
SOURCE: replacement circuit board
http://www.youtube.com/watch?v=23ZgWaVEQjA (sensor speed) Test.
Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
Test and see carefully the main motor, +loose cables+solder cool+bad contact+corroded terminal wires. Clean+Tight wires.Of course retight terminal fuses or breaker. And observes the videos +Tips Carefully.
Posted on Nov 13, 2011
Everything works except the Treadmill motor ? Incline works OK, belt doesn't turn at at all. Model EPIC View 550
1) You have problem with LUBE deck belt, this happen because the lack of maintenance, you must lube EVERY week, use 100% silicone lube. Maybe you have WORN deck belt,
2) LUBE the rollers bearing too, use wd-40
3) Test the drive belt motor, see for break, or worn, and replace or tension by 1/4"
4) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for help and troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board controllers is faulty. God bless you. see the block diagram attached.
Nov 25, 2012 | Epic View 550 Treadmill
I have a Healthrider R65, engine works wellbut when I step on it skips and stops for afew seconds my husband adjusted belt on each side but is till not going smoothly please adviceI bought from my fri
1) Lube the deck belt, this produce enough friction between deck vs deck belt, and shut down for to protect the electronic system
2) lube the rollers bearing very well.
3) Test the drive belt and replace
4) Test the motor input voltage, if there are the motor need repair.
5) test the output voltage board, for input voltage motor, if there are not the board is faulty.
God bless you
May 11, 2012 | HEALTHRIDER R65 Treadmill
I have a proform 320x treadmill and it was working fine but now the belt wont move but the console is still working fine
lube the deck belt inmediately. proceed in according with the instruction manual maintenace You have some deck belt worn.2) test the drive belt for replace if necessary 3) test the input voltage motor, if there are the motor need repair 4) test the output voltage from motor board, for input voltage motor, if there are NOT, the board is faulty.
sincerely. God bless you
Apr 28, 2012 | Exercise & Fitness
I have a Healthstream Ge3400 Lightning treadmill and I need to know how to tighten the belt as I can't find the user manual for it, It has been ages since it has been used and when you walk on it even...
hi,
Here is the steps to adjust the treadmill belt,
(1). Turn off the treadmill and remove the plug from the wall outlet to make sure it doesn't turn on during the readjustment process.
(2).Tighten the roller bolts on the rear of the treadmill belt with an Allen wrench. Tighten both the right and left bolts with 1/4 turns.
(3).Avoid tightening the bolts more than 1/4 of a turn at a time. If the belt is tightened too much, it may cause damage to the belt, which would require a replacement.
(4).Plug the treadmill into the wall and press "Power."
(5). Select a program and begin walking. If the treadmill is still slipping, turn off the treadmill, unplug it and tighten the bolt a 1/4 turn again until it is properly adjusted.
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt
Sep 04, 2011 | Exercise & Fitness
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
We purchased a reebok edge 2.2 treadmill about 3 weeks ago, a couple of nights ago the electic trip out whilst using the treadmill and since then the belt hasn't moved the display still works and counts...
i had the same problem, i beleive its the motor it may have burnt out.
only had it less than 4 weeks, argos sent a replacement treadmill and took the broken one away.
Feb 11, 2011 | Reebok 8000 ES Treadmill
The walking belt on my Proform 620 weight loss treadmill is very slick, almost dangerous
You can usually find the screws to tighten the belt at the back of the machine - but be careful not to tighten too much. A quarter turn may be all that is needed. A gentle tug will get the belt back into alignment if it is askew. Remember that if you have trouble tightening or realigning the belt, you should seek advice from the manufacturer or the fitness store where you bought your treadmill exercise equipment.
Most new treadmill machines do not require belt lubrication, and therefore you should only lubricate your belt if the manufacturer specifically recommends it. Most of the manufacturers who do recommend regular lubrication sell kits with instructions and all the equipment you need to make quick work of the task.
Post further comments for more help or information.....
Good Luck!!
Thanks
Dec 04, 2009 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
87 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
