Question about Korg Ga40 Guitar Bass Tuner W Batteries
Thanks for the reply...using the tuner, I tune the main 6 as I would a 6 string acoustic, now, are all the smaller 6 tuned 1 octave higher? and if so, how do I set the tuner, or how will it show on the tuner?
2 Suggested Answers
  • 5603 Answers
SOURCE: I tune my bass guitars
Make sure you have adequate input level to the tuner... some guitars MAY have inadequate output to be recognized CONTINUALLY by the tuner.
Posted on Jul 05, 2011
How change strings gibson guitar?
One of the best was to keeping your guitar in tune, is to also string it correctly and use new strings . Make sure the first winding of a new string around the tuner post goes over the exposed tip of the new string. The rest of the windings go under the exposed tip of the string. This will keep the string clamped firmly in place. Use 4-5 turns around the post for unwound strings, 2-3 for wound strings, in a downward spiral towards the bottom of the post as shown in the photo.-Tom, 30yr player.
Apr 15, 2016 | Gibson Les Paul Studio Electric Guitar
How do I set the tuner to tune at different keys?
Good question, tuners can be simple and some are complicated
a basic automatic guitar tuner you would not have to do anything to the settings, just tune normal on the E string then slowly down tune to D most tuners are a little sensitive, so go slow
and one thing I always do is go lower than the note I'm tuning to then tune up tell it's correct, strings seem to stay in tune better
Hope this helps ?
and if you have time check back on my profile
I will be doing some video tips this weekend
showing tuning, and some basic guitar repairs
thanks for your time
Mar 06, 2015 | Music
I tune my guitars at 400 using a clip on tuner,which I believe is concert pitch I've recently bought a 5 string blue grass banjo .I set tuner to c mode to tune banjo is this correct
Actually, concert pitch is A=440 rather than A=400. Normally a 5 string banjo is tuned G (octave) D G B D though many variations exist.
Feb 20, 2015 | Ovation Music
How to tune 12 string acoustic with ga40
Unfortunately, the manual on
http://www.korg.com/us/products/tuners/ga_40/
indicates that 12 string is not supported.
The owners manual can be downloaded at
http://i.korg.com/uploads/Support/GA40_EFG1_633661472559800000.pdf
The YouTube tutorial is at
https://www.youtube.com/watch?v=Of4CRajvq0E
with a 12 string, you can often tune the octave until the tuner sees the matching note. It won't see the correct string number, but an A note is an A note, whether or not it's an octave higher.
Hope that this helps.
Nov 15, 2014 | Korg Ga40 Guitar Bass Tuner W Batteries
How to tune 12 string guitar with ga40
Just use as if you are doing a 6 string ( instructions in the pack ) only play one string in each group at a time. The thinner string in a pair should be exactly one octave higher than the thicker string. Strings of the same thickness are in unison ( sound the same pitch )
How to tune the peavy guitar
well. this may sound retarded but every guitar is the same google or youtube how to tune a guitar, also get yourself a guitar tuner there cheap and affordable
Jun 15, 2011 | Peavey Electronics Peavey Predator Plus...
Hi, i have a acoustic guitar and i am trying to tune it but i do not know how to use the Matrix Chromatic Tuner SR-1050
Hi
Simply turn the tuner on using the power button. Play an open string note close to the tuner (no more than about 1/2 metre away) - for instance the low E on string 6.
The built in microphone will pick up the sound and, if your guitar is reasonably close to being in tune the led light labelled 'E' will illuminate on the lower scale on the tuner along with one of the three other leds to indicate whether the note is flat (b), in tune (green) or sharp (#).
Due to harmonics any or all of these three leds may flash but it is the one that is on the most that matters.
Adjust the tuning peg until the green is on constantly when you play the string.
Move on to the next string
Note - if the string is more than a semitone sharp or flat a different light may flash (e.g if the low E string is 3/4 of a tone flat the D light will come on).
If you wish to tune your guitar to another instrument that is not at perfect pitch (and perhaps cannot be easily adjusted - like a pipe organ) you can use the calibrate button to adjust the setting of the tuner. This temporary recalibration will be lost when the tuner is turned off.
Mar 01, 2011 | Matrix Auto Chromatic Tuner Sr1050
Is he tuner supposed to light up green when the string is correctly tuned?
Before turning the unit on, press and hold down the calib/batt switch to check the condition of the battery on the battery meter.
Then either plug in your electric guitar to the input side of the AG-6 or if tuning an acoustic guitar without electronics placing the AG-6 near the front of the guitar should work. You will not need to press a button to select which string you are about to tune. The AG-6 will detect it and the corresponding light will turn on when it is tuned within range.
Turn on the AG-6 and start by striking the low E (thickest) string while open. This is the number 6 string or 6E. Slowly turn the guitars low E tuning key untill the red LED below the 6E marking on the AG-6 lights up. Continue stricking the open string and turning the key untill the needle centers on zero and the 6E light remains on.
Repeat this for the open A string untill the 5A light turns on and the needle centers on zero.
Repeat for the remaining four strings, 4D 3G 2B and 1E, being careful not to over tighten and break them.
Tip: It may be a good idea once the low E string is tuned, to tune the rest manually, especially new strings or strings way out of tune. Then tune again using the AG-6 tuner.
If installing fresh strings you will probably need to stretch each string and re-tune, possibly several times, before they hold their tuning.
Feb 19, 2011 | Fender AG6 Automatic Guitar Tuner
Need Korg GT-2 chromatic tuner help
well i hope you've figured it out by now, it's a really cool looking tuner and i love it. but if you are still having problems...
the switch on the left side: OFF, ON, LMP (ON with a little light so you can see in the dark)
The number and letters you see across the top of the interface indicate which string it is tuning to. 6E is the low E string (the thickest one) and 1E is the high E string (the thin one on the bottom of the guitar), i've seen many people get confused when they've tuned those two.
You can leave the tuner in auto and it will pick up what string you are trying to tune. but if you are having problems getting the correct string or whatever the case is, you can switch to manual mode. click the only button on the tuner and the specific string will light up on the interface.
If you press and hold the button, the tuner will go into flat mode, tuning all the strings flat.
once you have the right string and you're tuning it in, you want the needle to be centered.
that's pretty much it. enjoy!
Jan 05, 2010 | Music
LP epiphone 100 "g" string problem,
after tuning ....put a capo on ... if this stops the problem then the cause must either be
1 the string catching in the top nut or
2 a faulty machine head
if it still goes out of tune with the capo on then look at where the ball end of the string sits
Feb 02, 2009 | Epiphone Les Paul 100 Electric Guitar
Korg Ga40 Guitar Bass Tuner W Batteries Logo
15 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
