My computor does not keep the time and date after closing down and restarting.
  • 32 Answers
Internal battery needs replacing. If it is a desktop PC it is usually fairly simple, just remove the CR2032 cell battery from the motherboard and replace with a new one. Laptops can be more difficult as the battery may be soldered to the motherboard, usually requires the laptop going to the repair shop.
Posted on Nov 17, 2014
  • gary dewhirst
    gary dewhirst Nov 21, 2014
    thank you for your help but after replacing the battery the time and date still does not stay on. ?
How to change dates on my personel computor
Click on the Date at your taskbar. When the analog clock shows up, click change date and time settings. A popup windows will appear.
Then, click change date and time, and seti it as your preferred. Click ok and it's all done.
But if you restart the laptop or pc and you date reverse back to previous one, then you need to change the CMOS Battery inside.
Generally, the battery is the flat one used in the watch but the size might be different for some model.
Aug 27, 2014 | HP Pavilion Computers & Internet
HAVING BEEN WORKING ON COMPUTOR.WENT AWAY LEAVING COMPUTOR ON .ON RETURN COMPUTOR HAD GONE DOWN .UNABLE TO RESTART COMPUTOR .HAVE TRYED NEW LEAD AND AND CHARGER.COMPUTOR 18 MONTHS OLD.
HI,
Remove your battery and then connect it with the charger to the power outlet,press the power button for 30 sec and it should turn on.
Let me know the result.
Aug 27, 2008 | HP Computers & Internet
Whu do I keep getting a certificate error message on my yahoo account
make sure you time, date and times zone is correct on your computer. If they are then I would do a full reset on you browser or try using a different browser.
Aug 14, 2014 | Gateway Computers & Internet
Delete bing off of my computor
Hi Gary,
Are you using Internet Explorer 8.. ?
have you tried resetting IE8 back to factory settings. tools> internet options> advanced tab> reset. This will reset IE.
When you open it next time you can delete Bing in the upper rt corner there is a pull down arrow that says "Manage search providers". Click on that and you can delete or disable Bing
Restart your PC once after you have done it
Regards,
Sean
Feb 17, 2013 | Dell Computers & Internet
I can't surf gmail.com.there is a certificate error
Certificate errors are typically caused by an incorrect date or time in your operating system's calendar.
To set your Date and Time Properties in Windows, please follow these steps:
  1. Double-click the time in your taskbar to open the Date & Time Properties menu.
  2. From the Date & Time tab, verify that the appropriate month, day, and year are selected.
  3. Click Apply to save any changes you make.
  4. From the Time Zone tab, verify that your time zone is selected. If the time zone in which you are located is not displayed, select your time zone from the drop-down menu.
  5. Verify that the box beside Automatically adjust clock for daylight savings changes is checked.
  6. Click OK.
  7. Close all your browser windows, restart your browser and try logging in again.
Mar 28, 2011 | Google Gmail
I want my pictures has the date on them when i downloaded to my computer. How to set this function? Sorry for my bad english.
Press [MENU/SET]. Press up/down to select [CLOCK SET]. Press up and down to set time. Under Appearence set date, time and the display order for the date and time. Press [MENU/SET] to close the menu.
You can read more about this in the user manual, page 19: http://panasonic.com.au/content/library/files/F002107.pdf
Jan 13, 2011 | Panasonic Lumix DMC-LS80 Digital Camera
My date keeps changing each time i reboot my computor and have to keep restting the settings where can i find the cmos battery and change it as been told it could be this as the rest of computor is fine...
the cmos battery will most likely be a 3volt coin cell battery. it has a part number of CR2032. 90% of all pc's use this battery as the cmos battery and can be purchased just about anywhere. here are some pictures of the battery although it can be in a different location on your particular motherboard.
Aug 11, 2010 | Computers & Internet
MacBook locked up, won?t close down
The first thing to try is this: It is a keyboard shortcut to shut down a mac laptop. Press the control key (ctrl) at the bottom and press the eject button at the same time (top button all the way to the right which looks like an arrow pointing up with a line under it). This should bring up a window asking if you want to restart, sleep,cancel or shut down. Click Yes to shutdown! If this does not work, here is the second option. Press the power button down on the upper right side,and just hold it down until the computor turns off. I have done this many times with my own computor when it has crashed with no ill effects, I have heard from Apple that it is not good for your computor and can cause problems, so I would only do this if the keyboard short cut does not work Good luck and if you find this helpful please comment!.
May 17, 2010 | Apple MacBook Pro Notebook
My laptop wont boot up and just resets itself help!!!!!!!!!!!!!
Try this turn off.Restart hold F8 Key. A menu will ask How to start, Chose Safe Mode.
If unit starts you will have limited use to find out what is causing the issue.Go to start click it then chose system restore and chose a date that unit started(you will lose some programs that were installed after that date but not data in files.If you don't want to use system restore you can try to 1.remove a new program that you installed and is causing the problem.2 disconect any new hardware.3.click start and click control panel,system,device manager,hardware and look for anything yellow, expand if you can to see any yellow ! marks thats your problem.Remove uninstall unless you need it.Restart,I have used System Restore many times it will fix your PC.Good Luck
Sep 04, 2009 | Computers & Internet
Computor running slow
restart your computer in safe mode and refresh it to the last point it worked properly. its usually when you had your last up date on windows
Mar 14, 2009 | Compaq Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
