How remove a protector from your flash drive?
    Problem Solver:
  • 6 Answers
Hi Kathelyn,
Can you please explain the issue you're having. I.e what the protection is stopping you doing? If could be a simple switch on the flash drive itself or a permissions setting. If you can provide a picture, make and model of the drive that would help too.
Regards,
Markus
Posted on Nov 18, 2014
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
My 4 males A-plug of USB flash drive are scratched, how to fix it?
Scratches should not stop it from working unless a lot of the gold contact has been removed. Try cleaning the contacts.
If still no work, it may have been blown up or physically damaged.
Sep 17, 2013 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to unlock snadisk pendrive
This link may help
http://www.tomshardware.com/forum/284827-45-remove-write-protection-flash-drive
Apr 04, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to put photos onto flash drive?
If you are using a Windows Computer, when you plug in the flash drive into USB port, you should get a message on the screen that says that you have installed a new removable drive. It will ask you what you want do next and one of the options would be to copy your photos. Note which drive letter the new drive is using - if you want to copy files manually, open My Documents, select My Computer on the left side panel, and select the drive that matches your Fllash Drive. When it opens, you can open. A second window to the location where your photos are, and then just copy and paste, or drag and drop between the two windows.
Jun 15, 2012 | Zeikos USB 2.0 SD/SDHC/MMC Flash Memory...
Write protector
Sir I'm sorry to direct you but you will rather undersand better at this link i'm sending http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/ your problem will be solved for sure...
Jun 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The protector flashes STR DE625
Chances are it will need replacement parts (output transistors and a couple of resistors) Probably best left up to a repair shop tech.
Feb 01, 2010 | Sony STR-DE625
I used Windows to format 4gb memory stick PRODuo, now what?
your 4gb drive has definately a partition virus.
i recommend u to use net protector a virus removal software to tackle this problem
may be demo version will not remove the virus but clean any malware and inform you about the virus.no other software may help as this 4 gb has a partition virus and there is an unseen partition (hidden one) on the drive... which the net protector will delete.
datarecoveryfactory
Sep 06, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Computer won't power on(my daughter's)
Your fuse probably turned off on you since you were using too much power. go outside your house and there should be a fuse box and flip the switch to the room where your computer is located
Dec 30, 2008 | Dell Dimension™ B110 PC Desktop
ONKYO DR 90 STANDBY LIGHT FLASHES UNIT WONT START
hello sir
if protector activated its means there is shorted speaker connected to your amplifier,try to remove all speaker and turn on your amplifier,then make sure your amp volume is in low position.if the protector is de-activated its means one of your speaker is shorted.then try to find out
Dec 13, 2008 | Onkyo DR90
Protector flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Oct 05, 2007 | Sony STR-GA7ES
Computers & Internet Logo
David Payne
David Payne
