<!-- from fixya rte -->How does the different wash cycles work - Washing Machines
What causes a maytag neptune to skip wash cycle?
Does it work in Wash Cycle on a different selection? Sounds like your Board has an Issue and needs to be replaced.
Jul 20, 2014 | Maytag Washing Machines
Indesit washer dryer 966w It will run all other cycles except a wash cycle. If I put it on a wash cycle it doesn't work but any sort of rinse or spin or dryer mode then it works???!!! Can you explain ??
Plug on motor (Multi-plug) has a burnt out wire as it has different speeds. Remove and check the plug (top comes off). Any burnt wire needs to be cut back to clean copper and refitted into plug.
Dec 07, 2013 | Washing Machines
My washing fills and drains properly, but will not agitate or run the spin cycle. I sounds like it is going through the cycle properly, but will not turn the drum (spin cycle) or agitator.
Try picking a different wash cycle, instead of your annual quick wash cycle opt for the longer wash cycle and then you may find that the spin cycle may kick-in, hope this works for you, good luck!
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Wont start cycle
there are two different cycles , WASH CYCLE , and RINSE CYCLE , witch one NOT working.
Apr 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
