Eio ap-1680, win7, driver
I need the driver for this card and win7
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
I can understand your problem, I thought I was going to have to give it a miss as all the drivers I found finished with XP or Windows 2003. However I did eventually find this one.
EIO AP 1680 ATA133 RAID Controller Drivers Download for Windows 7 8 XP...
Which appeared to detect my Win7 installation, and select the right driver. Being sceptical I fired up an old computer and tried the same site. It obligingly came up with the same driver but did detect the OS as XP Pro correctly. It would appear probable that this driver will work.
Good luck.
Posted on Nov 17, 2014
Error code 0b0004 00000011
-Check that the cable from the Ink Supply Station (ISS) PCA to the Ink Supply Station is correctly connected.
-Faulty APS. Replace the APS (See Air Pressurization System (APS)).
-If the error code continues, replace the Main PCA.
Apr 03, 2015 | HP Designjet 5000ps 60-inch/uv/postsc...
What does the error message EI0 1 Mean on the 8150dn printer?
EIO is the External Input Output slot that is on the formatter of the printer. the 8150 has 2 EIO slots (EIO 0 or EIO 1). One of the slots is probably the JetDirect card (network card) for the printer. The second slot might be a hard drive but is usually open.
If you are getting a EIO error first try reseating the JetDirect card (power off the printer first). If you are still getting the error pull the card and power up the device with out the card installed. if the error goes away power down the unit and install the card in the other EIO slot. if the card works you have a bad slot on the formatter but you should be good to use the device. If you get another EIO error the card is probably bad.
Mar 10, 2015 | HP LaserJet 8150 Printer
81.0180 EIO 1 error
On the back of the printer where the network cable is plugged in, in your case it is EIO slot 1.
The problem could be the slot(EIO 1) or the JetDirect card that is plugged into that slot.
Power down and loosen the two screws on the JetDirect card and reseat it. Power up and try using the printer. If the error persists, power down and remove the JetDirect and plug it into EIO 2.
There are two screws that hold the EIO cover on. Power up and try the printer. If it works, take the two screws and the cover and use it to cover EIO 1. And you are good to go. If it fails again with a 81.02, the JetDirect may need changing
Nov 01, 2011 | HP LaserJet 5100 Printer
Can't find any of my software
    M230_KBCBIOS_R1.12 Change Notes: solve second battery charge problem
    http://us.getac.com/AP/MISC/M0100/F0110_DownLoad_File.aspx?bullid=AllBull&fileid...
    M230-N2_KBC BIOS_R1.02 Change Notes:1.main battery shutdown voltage from 9.8V to...
Jun 14, 2011 | Getac M230 Notebook
I have an HP 4000N printer that is showing an E10 error. Can you advise what the problem is? Thank you.
EIO Error: Has to due with the additional card or hard drive on the back of the printer. If it's a networked based printer try the following:
Power off machine and unplug power cord.
Remove the network card from the EIO slot
Remove the cover from the other EIO slot (either below or above) and insert the card into that slot.
Power machine back on, see if error comes back.
If error is still present:
- Remove the card turn machine back on and see if the displays comes to ready.
If machine does come to a ready state than I would recommend:
- Replace the Network Card
If after replacement of card and attempted both EIO slots. Then you will need to replace the formatter.
Hope this helps!
Mar 07, 2011 | HP LaserJet 4000n Printer
Problem with the HP LaserJet 4050 Printer 82.0180
The 82.XX error represents that the External Card which is located in the formatter of the machine, either is bad or the port in the formatter is bad (This could be a Network Card or a Hard Drive really depends on your machine.)
Recommended Solutions:
Please make sure you turn off the machine before removing the card!
Remove the card from EIO slot 2 and plug it into the EIO Slot 1 is the card still does not work then the card will need to be replaced.
If both the EIO slots do not recognize the card. It's most likely the card, however it could also be the formatter.
Oct 20, 2010 | HP LaserJet 4050 Printer
Hp Laserjet 2300n printer with error 81.0180 EIO 1 ERROR
You have a problem with the device plugged into EIO slot 1. Most likely it's a JetDirect card. Turn power off and reseat the card. Power up, if problem is still there put the card in the other EIO slot. There should be 2 EIO slots. If it still fails you will have to replace the JetDirect
Oct 07, 2010 | HP LaserJet 2300N Printer
Trouble with Samsung 2233RZ
The same to me
I think the monitor is broken
Sep 06, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
Remove the EIO Card (if installed) and make sure that the Hard
Disk Drive is installed correctly by pushing it firmly inwards and
checking that the two installation screws are completely
tightened. Switch the Printer ON again. If the error codes 09Axxx
or 09Bxxx appear then replace the Hard Disk Drive.
n If the Error Code disappeared after removing the EIO Card, then
switch the Printer OFF and reinstall the EIO Card, making sure
that the two installation screws are completely tightened. Switch
the Printer ON again. If the Error Code reappears, then the EIO
Card could be faulty. Replace the EIO Card.
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Print to make sure that the Hard Disk Drive is functioning
correctly. If the Error Code reappears, then use the above
information to troubleshoot the problem
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
Widescreen 22" monitor won't stretch to fit screen
Without more details, it is really hard to provide assistance but here are some general items without knowing the model Monitor, the video card or the operating system you are using.
Generally (I can't know for sure without the LCD model) 22 inch LCDs have an optimal resolution of 1680 by 1050 pixels.
So the first thing you need to do is ensure that the video card display resolution is set to 1680 by 1050. If 1680 by 1050 is not an option in your display properties (In windows XP, right click the background, click properties, click settings tab, then slide the resolution bar to 1680 by 1050. Click OK) then try upgrading your video driver.
If that doesn't give you the 1680 by 1050 option, then your video card may need replacement with a better card.
Jun 12, 2008 | Computers & Internet
64 people viewed this question
jasbo
jasbo
