HOW TO FAX - Office Equipment & Supplies
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 12 Answers
  1. Make sure the fax machine is plugged into a power source and also plugged into a working phone jack.
  2. Turn the fax machine on.
  3. Obtain the fax number of the destination fax machine.
  4. Gather the documents you want to send and put them in the order you want them to be received.
  5. Fill out a separate piece of paper called a coversheet with the recipient's name, fax number/phone number, your name, your phone number, a short message and number of pages (including coversheet).
  6. Lay the documents face-up in the fax machine feeder tray with the coversheet on top
  7. Dial the recipient's fax number - put 9 before the number and area code
  8. Press the "fax" or "send" button, depending on the particular fax machine model
Posted on Nov 17, 2014
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
Iam getting remote fax error
Please try this approach:
1. Try to resend the fax. There may have been a problem with the quality of the connection.
2. Decrease the transmission speed of your fax modem. Press Setup button > Fax Setup > Dialing and Sending > Max Send Speed > 9600. Resend the fax.
3. Re-register your user information - fax name and fax number. Some fax machines block faxes without sender information. Press Setup button > Fax Setup > Dialing and Sending > Your Fax Name (re-enter your fax name). Follow the same steps and go to Your Fax Number - re-enter your fax number. Resend the fax.
I hope this helps.
Feb 20, 2012 | Lexmark Platinum Pro905 multifunction...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Can I use my phone number as my fax number?
Yes. Use a splitter. If fax has fax switch built in then fax calls should go to fax only and not phone. A fax switch can be fitted separately.
Nov 17, 2009 | Brother IntelliFAX 1840C Plain Paper...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
How to send fax from computer ?
Please follw the below steps:
To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
2. Open the document that you want to fax.
3. From the File menu, select Print. The Print window opens.
4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
To Send a Fax From Fax Software1. Prepare the document that you want to fax.
2. Prepare a fax cover sheet, if desired.
3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6. Indicate whether you wish to send a cover sheet.
7. When asked to attach the file, follow instructions to attach the file that you want to fax.
8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
9. When the connection is made, the fax will be sent.
Thank you.....
Dec 08, 2008 | Office Equipment & Supplies
How do I fax?
Sending a fax from your computer requires a fax modem and that your operating system be configured to allow you to send and receive faxes.
to send from fax software
step 1 Prepare the document that you want to fax. Step2 Prepare a fax cover sheet, if desired. Step3 Open your fax software - such as Microsoft Fax or Microsoft Exchange. Step4 Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item. Step5 Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed. Step6 Indicate whether you wish to send a cover sheet. Step7 When asked to attach the file, follow instructions to attach the file that you want to fax. Step8 When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine. Step9 When the connection is made, the fax will be sent. To Fax From Your Word Processing Program Step1 Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software. Step2 Open the document that you want to fax. Step3 From the File menu, select Print. The Print window opens. Step4 Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print. Step5 You will be asked to provide the recipient's fax number and other assorted information as with a fax program. Step6 The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
Aug 26, 2008 | Computers & Internet
Fax Confirmation Sheet
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
103 people viewed this question
jasbo
jasbo
