Right speaker channel doesn't sound clear anymore
The right speaker channel sounds distorted. does that mean it's going to burn?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 12 Answers
If it sounds like static, and the bass really effects the sound it is most likely going to blow.
I would suggest taking it easy on the volume or switching your volume settings so its more on the left speaker than that right, but still with sound coming out the right one. Just so you don't blow it as fast.
Posted on Nov 17, 2014
Testimonial: "i don't use it now and i think its 50% blown... but was hoping it might could be some thing else...."
  • 4 Answers
SOURCE: No sound from "Front Right" channel
I had a similar problem and i took mine back to circuit city and they told me it was a blown channel, which made since because i was pushing the receiver very hard when i first bought it.
Posted on Nov 29, 2007
SOURCE: Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Posted on Jan 23, 2008
  • 518 Answers
SOURCE: Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Posted on Mar 07, 2008
SOURCE: center speaker
I had the exact same problem. In order to "almost" balance the center with the other channels I had to give the center +12db gain and the other channels -12db. So after I got that far with level calibration I tried some tv sound, well the center although was playing sounded like the highs were missing and a bit distorted. This is the good part, I turned the volume all the way up real fast, somewhere near max something fixed itself, the center became very loud. Now it works just like new. Hope this helps. BTW, the problem existed the same for sub channel, so when the center started working so did the sub.
Posted on Apr 26, 2009
SOURCE: i have a Pioneer SX 203 stereo reciever which
Had the same problem. Another website suggested that the problem was that my speaker wires were too close to power cords. Turns out, my speaker wire was actually crossing over the surge protector!
I moved my speaker wires so that they were as far from power cords as possible and the problem disappeared. Not sure if this is a permanent solution but so far it has worked. By the way, this problem was driving me crazy. I originally thought it was due to a bad CD lens. Got the CD player cleaned was almost ready to buy a new receiver. Try this first before wasting money!
Posted on Aug 30, 2009
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
My bass isn't clear anymore. it sounds cheap and distorted. i tried adjusting the amp but it still sounds bad compared to how they sounded originally
Distortion of sound is commonly caused by a leaky electrolytic filter capacitor.
Your unit need to send to repair shop because it is quite technical diagnosing the faulty capacitor.
Also dry joints are going to consider because it will produced the same problem as what you encountered right now.
This is fixable anyway.
Thanks for using fixya.
Pls rate my help.
Jan 19, 2011 | Kicker CVR12 Car Subwoofer
Hi I have Denon 1910 7.1 avr, I bought last February 2010, the right front channel is producing some sort of sound distortion (hiss and popping sounds) when the receiver is turned on, I tried...
I SUSPECT THE CHANNEL IS BLOWN.YOU COULD TRY OPENING THE UNIT AND SEE IF THERE IS ANY GLASS FUSES.ONE MIGHT BE BLOWN.IF NO FUSES THEN TAKE IT TO A TECHNITION FOR REPAIR.THAT WILL BE YOUR ONLY OTHER OPTION.I KNOW,I HAVE HAD THIS HAPPEN TO ME.GOOD LUCK
Oct 18, 2010 | Audio Players & Recorders
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
GK 1001 rb speaker overload, is my guess
This problem is not likely to be a volume control problem. There is a transistor inside that is failing (getting noisy) when heated up. If you have no experience with amp repairs, do not attempt this as it is not simple to locate the defective part. Continued use in this condition can cause problems with the speakers. Please have this serviced by a repair shop with experience with GK gear.
Dan
Jul 29, 2009 | Crown CE1000 2-Channel Amplifier
Suddenly, my outdoor speakers sound kind of "muffled"
If these speakers are two or three way speakers, it is possible that the tweeter(s) are blown in them.
Try and remove cover to check.
If the sound is not distorting, but just flat and muddy its the tweeters.
Put the other ones on this channel, to make sure it is not the amp.
Jun 13, 2009 | Insignia Simulated Rock Outdoor Speakers...
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Dec 16, 2007 | Sony STR-DE625
81 people viewed this question
 Grubhead
Grubhead
