Question about Garden
My pto won't engage and ive jumped this directly and it works fine when I put a volt meter on the plug it doesn't have power .ive tried 3 different switches and still can't get it to work am I missing something simple ? Tommy
  • 603 Answers
Check for wires that are broken, or shorting to the body of machine. Do you have a fuse in this line, if so possibly the fuse is blown. Were the switches you used new or in good condition? Only you know what your looking at. GOOD LUCK FRIEND.
Posted on Nov 17, 2014
  • 3600 Answers
SOURCE: electric PTO does not engage on garden tractor
one in the seat one in the arm to lower the deck. What model?
Posted on Aug 20, 2009
heatman101
  • 43501 Answers
SOURCE: Starting my husky 2540 riding
Check all of the wiring to the switch and the PTO clutch. You may have a wire that is either rubbing on the frame and shorting out or the two wires are rubbing together and shorting out...you have stated that you have checked the wires, but make sure to untape everything and check all parts of the wiring...
If all of the wiring looks to be in good shape and there are no scraps or scuffs, then the PTO Clutch is going bad and the magnetic clutch is either shorting or pulling too much current to engage it.... it will need to be replaced... not an easy project most of the time.
These clutches often do fail, and because of the heat of the engine and such they are usually very hard to remove. Make sure to have a good puller before you even think of trying to get it off of the shaft.
Bottom line is that it seems as though the problem is probably the electric clutch...
heatman101
Posted on Aug 29, 2011
  • 6468 Answers
SOURCE: NO power to pto craftsman gt 5000
could be a clutch switch look at sears parts online for the location
Posted on Apr 03, 2012
  • 117 Answers
SOURCE: pto not engaging in john deere lx 167
Check the voltage on the wire(s) connector to the PTO switch. Sometime portion of the switch can go bad. If you have voltage coming in to the switch check the output voltage going to the clutch..
  • 6468 Answers
SOURCE: lawn tractor, blades won't engage
the circuit also goes to the trans so you can't mow in rev also on the brake/clutch pedal switch assuming you check the fuse already
Posted on May 11, 2012
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
I have a ariens zoom 1540 mower it runs fine but the blades wont engage to mow. It worked when i put away after last mowing and 2 days later it doesnt. Ive checked the wires off pto switch and they seem...
You've checked the wiring to the PTO and it looks OK. Does the PTO engage when the switch is thrown? Do you have a multi meter , so you can trace the voltage to the switch, from the switch to the PTO. You also should check the safety switch (s) which will prevent the PTO from engaging if there is a faulty switch. And it could simply be a fuse that has blown.
Jun 20, 2014 | Garden
John deere 111 dies when go to move it
I just got done with real similar prob my at first would start not rev up very well could drive it fine try to engage pto it die i checked everything carb back fire prevention was good cleaned carb seat switch checked out fine ignition switch had little corrosion changed it nope then it started to die after i started it and let out on foot pedal thought that was it checked with wires hooked up still get different readings each time unhooked switch it checked out fine then the seat switch would give me different readings on meter took it off test again fine was ready to have a fire sale on this pos i started to go through every electric con. Clean and make sure contact were good noticed a small crack on ignition switch female plug then found same on pto female plug got new plugs put wires in fixed everything
Jul 02, 2013 | Garden
John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Oct 24, 2012 | John Deere Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
Engine runs-- PTO will not engage after control switch is pulled
first check the connection at the clutch cub are know for this. also check the fuse block for a blown fuse. then still if nothing check to see if your getting voltage at the clutch. to do this unplug clutch and with a volt meter test for dc voltage. it should read 12-14 volts. if not try changeing the pto switch.
Mar 03, 2010 | Garden
Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Jul 31, 2009 | Husqvarna Garden
Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
Jun 30, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
