Question about Coffee Makers & Espresso Machines
DeLonghi Magnifica ESAM04.320.S - has problems delivering the ground coffee (from the beans) to the brew head. Instead, the grinds are backing up into the ready ground area. The machine is then produc
DeLonghi Magnifica ESAM04.320.S - has problems delivering the ground coffee (from the beans) to the brew head. Instead, the grinds are backing up into the ready ground area. The machine is then producing weak coffee with slim "pucks" as the full amount of coffee is not getting onto the brew head. Is it likely to be the beans or something else please?
espressodoc
  • 29 Answers
SOURCE: Grind is too coarse and "pucks" are wet and fall apart.
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
Posted on Jul 29, 2007
  • 14 Answers
SOURCE: unable to make coffee automatically using whole beans
The rivets in the back of the Jura Capresso units are actually oval security screws. The bit that removes these screws are made of a very hard metal and cost me over $50.00 two years ago. Also many people who attempt there own repairs tear off the little plastic tabs that keep everything together nice and tight. We repair Jura Capresso Krups Bosh etc. www.hotncold.com
Posted on Aug 03, 2008
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have had the same problem the only way I could get it to brew would to use the program quantity feature every time. I was going to take it in today and decided to restore the factory settings and now its working like it should. This seems to be a circuit board issue Ouch! I have another issue with the steam, if I take the knob off it works if I don't it doesn't glad I bought a 2K model GRRRRR!
Posted on Jan 25, 2010
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
Delonghi problems
More than likely the grinder is either not grinding at all or there is a blockage preventing the grounds reaching the brew chamber.
Jul 18, 2014 | DeLonghi Esclusivo Gran Dama EASM6600...
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My delight magnifica is now grinding too much coffee causing lots of excess falling into machine. How to I adjust the grinding time?
I had this same problem and discussed it with DeLonghi customer service. My machine was grinding 20 seconds for a double shot and ground coffee was coming out of the top and spilling over inside what a mess! DeLonghi thought it was potentially a problem with the control board - grinding time too long - which is an expensive repair. I also called the local factory-authorized service and described the same problem. They asked what kind of beans I was using and I answered Starbucks espresso. They said that Starbucks is too oily, clogs the machine, and that I should try beans that are lighter. I also checked with an engineer who used to work at Starbucks and he made the same guess. I tried an Italian roast espresso from a local market and it worked! I've had no problems since. The new beans cleaned out the oils and I'm getting great shots. This is a good machine, but is best making single shots.
Jun 11, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Can you grind hazelnuts with the coffee in our 3000 magnifica
I would not do this as hazelnuts are oily and will probably gum up the grinder.
What you could do is but a few ground hazelnuts in the pre-gound chute at same time coffee beans are grinding. These will go into brewer unit at same time as coffee.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica door comes open after grind and just before brew?
try changing the defusser..... bsc appliances 07779933829 postal service too.
Feb 07, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Jan 13, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
47 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
