Question about Garden
My toro pto is not engaging and I've jumped it with battery direct and it works there doesn't seem to be power coming from the switch ive tried 3 different switch and can't work it out.
  • Eugene Rounds Nov 17, 2014
    Hi Tommy Virgato, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Need the model number to look electrical diagram to help troubleshoot your problem.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
Is it a zero turn if it is there is a fuse that runs the pto
Posted on Nov 24, 2014
  • Eugene Rounds Nov 24, 2014
    It does matter if it is a ZTR or a regulator rider some have a fused PTO circuit and others don't. Just worked on a JD737 ZTR PTO that was pulling over 16 amps when it should have been only drawing 6 amps; no fuse in the circuit.All ZTRs and regulator riders all have at least a main fuse but if it is blown then not even the starter circuit will work.This is why I always ask for the equipment info in order to look the electrical diagrams.
    I meant to say it doesn't matter.
  • 760 Answers
SOURCE: Battery isnt getting charged by
40b7c2b.jpgTry to always list the model number. Something like 917289472 would be the model number. Here is a wiring diagram for that model. Note the test voltages with unit running. Check the wiring from the regulator to the ignition switch and from the switch to the battery. It is possible for the ignition switch to be bad and keep it from charging. Test at these terminals with voltage tester. You should have more than 12 V at the regulator( diagram says 9-16 volts). If you need the manual you can go to www.searspartsdirect.com and download diagram. Enter YOUR model number. Good luck!
Posted on Oct 20, 2010
huffman49
  • 235 Answers
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Posted on Apr 03, 2010
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
  • 95 Answers
SOURCE: Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Posted on Jul 30, 2009
  • 218 Answers
SOURCE: Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
Posted on Jun 30, 2009
Toro 11-32 won't start.new battery. i jump the terminals it fires right up. 2nd problem is the deck won't engage I hit the switch and nothing I leave the seat it shuts off when engaged
Check and see if the Engagement termnal on the solenoid is getting power. If it is replace the solenoid.
As for the PTO check for at its connector for voltage. If voltage is there check for about 1.7 ohms resistance across pto coil. If it reads infinity or less than 1.5 ohms replace the pto clutch assembly.
If the pto reads less than 1.5 and there is no voltage at the connector than the pto switch is probably burned up due the shorted pto.
May 14, 2015 | Toro Garden
My pto won't engage and ive jumped this directly and it works fine when I put a volt meter on the plug it doesn't have power .ive tried 3 different switches and still can't get it to work am I missing...
Check for wires that are broken, or shorting to the body of machine. Do you have a fuse in this line, if so possibly the fuse is blown. Were the switches you used new or in good condition? Only you know what your looking at. GOOD LUCK FRIEND.
Nov 17, 2014 | Garden
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Toro Z4220 PTO problem
check fuse to pto dose pto click when you start the swicth could be that safty switch has come lose keeping pto from operation take off belt and by pass switch to pto see if it activates what you want to make sure pto didnt burn up im more thinking it is a relay gone bad or a blown fuse
Jun 26, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Motor stalls when PTO engaged
its ether the regulator or the stator in the engineas for as the pto killing the engine it might only need a govenor adjustment to take care of that problem
Jun 22, 2013 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Toro 265-6 model 72045 PTO clutch will not engage. PTO checked with 12V and works okay. Both relays checked and working okay. All fuses are good. Not sure how to check PTO switch. Any other suggestions on...
ohm out the clutch......should be 2-4 ohms any less means the clutch has an internal short and will need to be replaced. also check the saftey interlock module, however the modle numbers u gave do not come up, relays checked ok? how did u test them?
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
Pto clutch keeps shutting off
If you have not replaced the pto switch do so. If you have check wiring from switch to the pto coil. Many times the wiring at the pto coil is rubbed by the belt until it wears the wire into. You can also try energizing the coil to the pto directly from battery (With engine off of course) If it energizes and stays energized it is probably not the coil.
May 03, 2009 | Garden
Garden Logo
187 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
