Question about Stoves 720EF Electric Double Oven
How do I fix the lights on the clock?
Both ovens work but the timer lights and clock lights are not lit up.
I don't think that the lights are repairable,it looks to me that they are part of the timer display and if this is the case it would not really be a diy job.
Posted on Nov 17, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
I had trouble setting the time on the stove I have. I had lost the manual so I got in touch with the manufacturer and was sent another one. I suggest you get in touch with the manufacturer or the store you bought it from and go from there.
Posted on Nov 18, 2014
My Neff oven is displaying the locked "key" symbol...does anyone know how to unlock please?
Locking the oven:
Using the main oven function selector, switch 3 x in
rapid succession from the 'off' position to the
oven light function and back again.
- s - is displayed.
The oven cannot be unintentionally
switched on, e.g. by children.
To release the oven, switch 3 x from
the 'off' position to the oven light.
- s - goes out.
Mar 21, 2013 | Neff B1641 Single circotherm super...
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Mar 07, 2011 | Baumatic Ovens
When I turn on the wall oven it will not heat up, the light doesn't come on
If the oven element or the indicator light don't come on it sounds like a timer problem. I assume the oven has an electronic timer/clock. The timer must be in manual mode for the oven to work. If so, turn the oven ON. Then operate the clock/timer buttons to get it in the manual mode. Be patient. When the oven indicator light comes on it is in manual mode.
Please vote for me if this helps you.
Mar 05, 2011 | Ovens
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Mar 02, 2011 | Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Stoves 720EF Electric Double Oven Logo
79 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
